Software Compatibility, If on Pi then?
I need a sanity check here.  I'm a novice on my recently received Pinebook Pro, but I was hoping that if a software package is compatible with a raspberry pi ARM architecture, that it would also be compatible on the Pinebook.  Am I wrong here?
As an example, I installed Calibre from the software center and the program won't start.
Can I add repositories meant for the Pi and have them run on the Pinebook? Clearly I'm in over my head but I'm hoping to at least get a couple pieces of software running to keep learning.
I should mention I'm running on the recent default Manjaro installation based on kernel version 5.6.0.2.
One of the problems that ARM has, that also early x64 had, was multi-library. Meaning when x64 came out, old x86 software would not run if you booted a 64 bit OS. They solved it by having both 32 bit, (x86), and 64 bit, (x64), libraries and support. So you could run any Linux compatible x86 or x64 program, as long as you had all the dependencies.
At present, there does not seem to be this multi-library configuration for ARM, yet. The original Raspberry Pi's were 32 bit ARM. Newer ones support 64 bit ARM. So it's a toss up if the program(s) you want, will work. The original OS for the Pinebook Pros was 32 bit Debian. Now we are shipped with 64 bit Manjaro.
To be fair, most user type ARM computers are tablets, phones or single board computers. You use what they supported, (32 bit or 64 bit). It's only recently that Linux ARM laptops and some more powerful SBCs have make this desirable. (Chromebooks have an embedded OS, so again multi-library did not mater.)
This ARM multi-library feature is on my wish list.
Arwen Evenstar
Princess of Rivendale
I don't know what "software center" refers to, but you should be able to open a terminal, type "pamac install calibre", follow the prompts and you'll have a working app!
You may find most of what you want in the Manjaro repo's already.
(06-06-2020, 06:59 AM)rossk Wrote: I don't know what "software center" refers to, but you should be able to open a terminal, type "pamac install calibre", follow the prompts and you'll have a working app!
Thank you for actually answering the guy's question.
I had gotten on my "soap box", and forgot about the original issue, "calibre".
Arwen Evenstar
(06-05-2020, 04:43 PM)Arwen Wrote: One of the problems that ARM has, that also early x64 had, was multi-library. Meaning when x64 came out, old x86 software would not run if you booted a 64 bit OS. They solved it by having both 32 bit, (x86), and 64 bit, (x64), libraries and support. So you could run any Linux compatible x86 or x64 program, as long as you had all the dependencies.
I hadn't even thought of this.  My assumption was that x86 programs would run on x64, but that's all been because of multi-library being present on many non ARM systems.  I'm going to check out the last release of 32bit Debian and see if that fares better.
I used the wrong term for the "Add/Remove Software" men, which has a nice selection of software but few programs work.
Reinstalling with "pacman -S calibre" worked perfect, thank you!
  Error trying to update Manjaro software boosterh 5 9,248 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 216,510 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 5,760 11-25-2021, 05:59 AM
Last Post: mexsudo
  Running x86 software GloriousCoffee 19 39,943 02-15-2021, 11:43 AM
Last Post: jiyong
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 16,732 09-29-2020, 07:55 AM
Last Post: hmuller
  Package compatibility fcs 6 13,792 04-10-2020, 01:49 PM
Last Post: rempfer
  Arm supported software nabeel 1 4,785 03-18-2020, 08:47 AM
