Pinebook Pro Temps? 65C while playing music via youtube w nothing but a static image
I just installed debian bullseye t'other day, with the 5.5 kernel and I love it, mostly.
One thing that surprised me, and concerns me, is cpu temps.
While playing music on youtube with a static image, (no moving graphics), and reading one of my forums, I saw temps hitting 67C.
That's absurdelly hot, Even my big Nvidia cards don't see temps like that.
Now, ambient temp is 80f, no sunlight, and the body of the pinebook is scalding hot.
I pulled out my marble dough making board, and put the pinebook on top of it on the rubber stand-offs, not much temp change. When I moved the pinebook pro so that half of the rubber washers are hanging over the side, (thus the magnesium case is directly touching the marble) temps drop to a much more reasonable 42-55C.
Is this normal? I don't remember temps like this with the stock debian oldstable the pinebook came with.
htop shows 1.97, 2.6, 3.70 for load averages, most of it is firefox.
I'm looking at temperatures with gkrellm and inxi -Fix. the other temperature sensor (whatever it is) only reads 18C.
https://youtu.be/nsArbdB_XUY
Is what I'm listening to, as you can see, it's just a single static image, I am using a USB DAC, HiFimeDIY Audio SA9023 USB Audio type: USB
because the stock soundcard and speakers, well, frankly, blow. Using an external DAC is so much better, it's worth lugging around, especially since I don't have to lug around a power supply.
Laptop is plugged in, at the moment.
TIA, for any information, suggestions.
$ youtube-dl --list-formats https://youtu.be/nsArbdB_XUY
[youtube] nsArbdB_XUY: Downloading webpage
[youtube] nsArbdB_XUY: Downloading js player 85548937
[info] Available formats for nsArbdB_XUY:
format code  extension  resolution note
249          webm       audio only tiny   67k , opus @ 50k (48000Hz), 23.68MiB
250          webm       audio only tiny  103k , opus @ 70k (48000Hz), 31.75MiB
140          m4a        audio only tiny  131k , m4a_dash container, mp4a.40.2@128k (44100Hz), 57.36MiB
251          webm       audio only tiny  203k , opus @160k (48000Hz), 62.47MiB
278          webm       146x144    144p   50k , webm container, vp9, 30fps, video only, 9.55MiB
160          mp4        146x144    144p   67k , avc1.4d400b, 30fps, video only, 17.47MiB
242          webm       242x240    240p  135k , vp9, 30fps, video only, 17.43MiB
133          mp4        242x240    240p  138k , avc1.4d400d, 30fps, video only, 39.95MiB
134          mp4        364x360    360p  142k , avc1.4d4015, 30fps, video only, 27.79MiB
243          webm       364x360    360p  236k , vp9, 30fps, video only, 28.54MiB
135          mp4        486x480    480p  280k , avc1.4d401e, 30fps, video only, 49.47MiB
244          webm       486x480    480p  398k , vp9, 30fps, video only, 42.74MiB
136          mp4        728x720    720p  565k , avc1.4d401f, 30fps, video only, 91.54MiB
247          webm       728x720    720p  784k , vp9, 30fps, video only, 82.98MiB
137          mp4        1092x1080  1080p 1170k , avc1.640020, 30fps, video only, 153.07MiB
248          webm       1092x1080  1080p 1457k , vp9, 30fps, video only, 142.62MiB
18           mp4        364x360    360p  281k , avc1.42001E, 30fps, mp4a.40.2@ 96k (44100Hz), 126.92MiB (best)
It's not a static image. It's a video stream consisting of a long series of frames of the same image, and the video codec isn't smart enough to recognize that. Depending on the player size, you were still playing back 1080p video for, I guess, a long time. At 80F ambient, and, unlike the big Nvidia cards, the Pinebook doesn't have a fan.
Workaround is to install youtube-dl, grab your choice of the audio-only formats (150 or 251), and play it back with an efficient audio file player, not Firefox.
youtube-dl takes an inordinate amount of time to , well, do anything. Like 5-10 minutes. any suggestions? It does work, but spends most of its time doing nothing. I use it on other machines, and there's no lag at all. it's not like its doing anything, htop shows nothing, and iotop shows nothing. Again, it does work, just exceedingly slowly.
It doesn't delay on my PBP. There are a lot of debug options listed in the man page, try adding --verbose --print-traffic to see where it's getting hung up?
set youtube video to the lowest resolution.
your best bet is youtube for kodi right now. kodi supports mpeg2, vp8, vp9, h264 (8 and 10bit), and h265 (8 and 10 bit) hardware media decoding.
when we have vaapi support for hantro and rkvdec, then hwaccel will work on youtube etc. on firefox+wayland and chrome+vaapi patch.
There are a number of Firefox extensions that disable the video portion of Youtube videos. Maybe those would help.
  Boot Order in Pinebook Pro food 12 14,671 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 4,087 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,157 08-09-2025, 06:53 AM
Last Post: Sb2024
  What's a good image to use now? [tutorial help as well] frank_philip 40 26,867 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 14,916 03-10-2025, 01:55 PM
  Inexpected reboot during watching youtube video regivanx 1 2,961 10-19-2024, 06:02 AM
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,109 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,965 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,723 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 14,857 02-22-2024, 04:02 PM
