Pine book Pro Speakers
#21
Same with gaffers tape. It's expensive but it's the best all around tinkerers tape there is. Sticks like hell and leaves no residue
#22
(11-04-2019, 07:33 AM)zaius Wrote:
(11-03-2019, 10:25 PM)MrTester Wrote: I have included photos of my work, my preferred choice was athletic tape (woven fabric tape, with high adhesive properties).
Have you considered trying friction tape?  It's cotton cloth impregnated with rubber. Once used as electrical tape, it has good adhesion, it's non-conductive, and very durable.  It's generally 15 mil, so it might be thicker without being too thick.
I do not have access to any Friction Tape at home or at work currently. I would agree this may be the safest, and most functional option.
(11-04-2019, 07:04 AM)rick1959 Wrote:
(11-03-2019, 10:25 PM)MrTester Wrote: Greetings PBP friends,
Tonight I decided to dig inside and see what mechanical/ acoustical improvements I could make to the PBP speaker system.
Background: Initially when working on my PBP, I noticed when playing audio, the playback was extremely harsh on the ears and a significant amount of resonance in the palm rest (back side of the speakers) My main goal was to observe and find some mechanical isolation solution to improve audio.
Observations: After opening my PBP, I found the following, A simple speaker, isolated from the metal bottom of the laptop (and speaker grill/opening ) by an adhesive foam surround. The back of the speaker (magnet side) is directly adhered to the plastic palm rests, located in place by molded frame apart of the palm rest.
My initial assessment was that a significant amount of energy was being transferred from the speaker magnet directly into the palm rests, resulting in physical resonance and contributing to the observed acoustical resonance.  Considering the space as tight manufacturing tolerances, any mechanical isolation solution would need to be minimal thickness. With the above comment considering a MFG change could be considered, The cost of such options was in consideration.
I tested Duct tape, Electrical tape, and athletic tape. My intention was to cut just enough tape, to fit behind the speaker, and isolate it from the palm rest. All produced significant reduction in physical energy transfer into the palm rest. The acoustical improvement is reasonable in my opinion, I would like others to test if this is a significant enough of a improvement.
That's excellent!!
And sounds, forgive the pun, that the tape may be what relieves (absorbs?) the buzziness?
Clearer high level volume? Clearer in general?
Here's my thought, unsolicited: How about a drop of rubber cement on the magnet, sufficient to spread wide enough to cover the whole circular area of the magnet? Just enough to insulate the magnet.....
I'm not brave enough, nor have the time to try it right now. However, what do you think? :-)
Its not a 100% catch all to all audio artifacts, I would like to see if I could apply some native equalization, in addition to the fix. The main concern to isolate most of the energy transfer from the magnet to the palm rest body was my goal. This did improve some of the vibration, We are far from a nice foam filled speaker box, but much closer.
A dab of RTV silicone or rubber cement would also potentially be cost possible, and easy to transfer into the manufacturing floor.
-Happy Testing
(Posted from my Pinebook  PRO Mate)
Getting Paid to break your product (and make it better) since 2005
#23
That's excellent!!
With this setup, anyone would be unreasonable to think symphonic quality sound would come from it. Good, functional sound at a reasonable volume, ok....
And your thoughtful, measured approach seems to be getting good results. Likely reaching the cost/benefit pretty quickly.
Right now, I'm inclined to use a Bluetooth setup (earbuds or speaker) to have higher fidelity sound. That, I've found, is a clearly reasonable way to achieve higher quality sound. No screwdriver required!! :-)
And the search continues... :-)
#24
Unfortunately, I am having problems with Bluetooth over here.
If anyone else tests the tape/ RTV/ Rubber Cement trick. Please post your feedback as I would like formally put together a Tutorial.
-Happy Testing
#25
I wonder if using a few cut out pieces of the thin foam sleeve the PBP shipped in might fit in the tight area between the speakers and case. Anyone tried it?
#26
Lightbulb
I was having a lot of buzzing from my right speaker. I put a strip of masking tape on the back of it, and viola! Great sound at loud volume!
#27
(05-07-2020, 03:42 PM)TDC_PBP Wrote: I was having a lot of buzzing from my right speaker. I put a strip of masking tape on the back of it, and viola! Great sound at loud volume!
Puzzle on your implementation, please snap a photo. Thanks.
#28
Sorry for the late reply! All I did was open up my PBP and pry out the right speaker, which was buzzing, and put a strip of generic masking tape on the backside of the speaker, covering up the adhesive that that was holding it in place. That didn't cause a problem because the speaker was still held in place by the rail around it. If that doesn't make sense, I can take a picture for you, but I really don't want to take my Pinebook Pro apart any more then I have already, as it has quite a few of the cracks that are mentioned elsewhere in the forum. I am hoping it can make it until the ANSI keyboard upgrade kit is available
  Are you interested in a new design of Pine laptop? CleanEnvironment 2 5,090 11-12-2025, 02:33 PM
Last Post: WEF
  Pine Book Pro Charging Problems balin 7 14,210 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  how to get rid of heavy distortion from the speakers? stozi 2 4,917 02-20-2022, 05:46 AM
Last Post: stozi
  Up-firing speakers!!! mamboman777 6 10,956 07-28-2021, 02:54 PM
Last Post: mamboman777
  If booted with headphones in, sound comes from them and speakers stozi 6 11,119 06-11-2021, 01:27 AM
Last Post: dsimic
  Pine Key + Backspace/Arrow Keys not registering tslight 3 8,018 06-13-2020, 11:31 PM
Last Post: xmixahlx
  A request to anyone with a Pinebook pro / other Pine device.. account3122 14 31,630 06-05-2020, 02:52 AM
Last Post: icecream95
  Issues connecting bluetooth headphones and speakers jamathis 2 6,611 12-01-2019, 11:21 AM
Last Post: jamathis
