Link to the Official (from factory) manjaro image?
As Manjaro is now the default OS as shipped from the factory I'd like to flash my PBP to the "official" OS.
Can someone point me to the correct image?
I've looked on the Wiki and its still debian-centric and the Manjaro section has various different desktop options.
Looking in the forums there are versions 19 and 20 manjaro threads, so I'm not sure which is the correct one that will match the version flashed onto the PBP in the factory.
Cheers
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
Go to the Manjaro Arm forums and look for the latest release (20.0X). For the OOTB build, choose the KDE variant.
(05-19-2020, 08:10 AM)tophneal Wrote: Go to the Manjaro Arm forums and look for the latest release (20.0X). For the OOTB build, choose the KDE variant.
So its 20.0x KDE, thank you.
I'll head over there and give it a go.
Cheers @tophneal
Cheers @tophneal
Glad I could help. Just in case it helps anyone down the road: Manjaro's versioning is just like Ubuntu's "YY.MM". So this month's (May 2020) release would be 20.05.
(05-19-2020, 07:28 AM)gandlers Wrote: As Manjaro is now the default OS as shipped from the factory I'd like to flash my PBP to the "official" OS.
Cheers
Here is the link for emmc installer, https://osdn.net/projects/manjaro-arm/st....04.img.xz
And here the thread with all info to install it correctly, https://forum.manjaro.org/t/manjaro-arm-...sed/133374
See on  https://forum.manjaro.org/c/manjaro-arm/78 to get lastest updates from manjaro.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 4,496 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  What's a good image to use now? [tutorial help as well] frank_philip 40 31,747 07-18-2025, 07:28 PM
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,129 03-15-2025, 01:47 AM
Last Post: frank_philip
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 17,465 03-10-2025, 01:55 PM
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 7,255 02-19-2025, 12:49 PM
Last Post: zkajdan
  Official Debian support moonwalkers 64 121,492 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Manjaro Sway Theme Broken Eighty8 1 4,056 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 17,387 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,564 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,919 01-19-2024, 11:32 PM
