Android flashed, SD card shows empty?
So I followed the directions from the Wiki, downloaded PhoenixCard, downloaded the Android image, and tried to flash my SD card (16GB).  Ran PhoenixCard software, following the directions, and it finishes, no errors given, says "magic complete".  When I look at the card on my computer though, it doesn't show any files, and shows the card has full capacity still, no storage used.  Is this what I should be seeing?  I thought it would show some amount of memory used on the card.
I've tried with using images "sun50iw1p1_android_db1000_uart0_0216.img" and "android-ver5.1.1-20160303-pine64-phoenixCard.img" so far, but haven't seen anything on the card afterward with either.  Am I missing something, or does this sound right?  New to this stuff, so forgive my ignorance if I should not see anything.  Thanks.
(04-21-2016, 09:56 AM)montero65 Wrote: So I followed the directions from the Wiki, downloaded PhoenixCard, downloaded the Android image, and tried to flash my SD card (16GB).  Ran PhoenixCard software, following the directions, and it finishes, no errors given, says "magic complete".  When I look at the card on my computer though, it doesn't show any files, and shows the card has full capacity still, no storage used.  Is this what I should be seeing?  I thought it would show some amount of memory used on the card.
I am having that exact same issue.
I have tried 3 different micro SD cards, one standard SD card on 2 separate computers both running Windows 7.
Same here... I just got Pine64 2gb yesterday. I tried to download Remix OS and it wont start up and it only show logo Remix os for more than 30mins. trying to get it work.
Screenshot:
Note Phoenix completes just fine. Drive K is empty.
Did you try inserting the card ine the pine, turn it on and let it sit for 15 minutes? Windows doesn't understand non-windows partitions, so it might be a question of bad interpretation.
Not shire if it is the correct answer but the filesystem for Android (ext2, ext3, ext4) is NOT possible to show in Windows. This is a linux-filesystem so I guess you can get it to show if you use linux.
If anybody can verify or correct me it would be nice.
(04-24-2016, 12:52 AM)Tarjei85 Wrote: Not shire if it is the correct answer but the filesystem for Android (ext2, ext3, ext4) is NOT possible to show in Windows. This is a linux-filesystem so I guess you can get it to show if you use linux.
You are correct, the Android and Linux build are on EXT4 format. Windows will not display EXT4 partition.
Thank you for verifying this. From now on I'm sure about this.
Thanks everyone. I was seeing the same thing as RAGE Sonix, completed, full space available. I haven't had the chance to play with the Pine yet, I was doing this at work last week before going out of town. Glad to hear this should not be an issue. Hopefully I'll get a chance to fire it up tonight and get going with it. Thanks again!
Just keep trying. It took me about 30 attempts. My windows sees the files on the card just fine. I have no idea what these people are talking about, not seeing the files....
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,610 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 607,286 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,184 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,031 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,683 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,250 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,564 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,748 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 409,282 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,506 02-26-2019, 11:58 AM
Last Post: Twistedx
