Ubuntu Touch with OTA updates
Hello everyone,
Here are the UT images you should use from now on, as these images include OTA updates (obviously, get the latest one).
OTA updates can be found under settings -> updates
You download the update and press "install & reboot", the update process including reboots is completely automatic - you don't need to do anything.
You no longer have to reflash your UT image, just use the OTA updates from now on.
[edit] Stable OTA pushed on 18 June, 2020 includes crust and support for incoming / outgoing phone calls as well as much refinement, fixes and extras.
Is there anything specifically new in these builds other than OTA?
(05-06-2020, 11:24 AM)somken Wrote: Is there anything specifically new in these builds other than OTA?
Many fixes and improvements as well as much faster performance.
build #7  no success getting cellular working (consumer cellular (att) doesnt seem to keep the APN`s --- i made sure they were saved, rebooted, and lose them and or the check marks dont stay ( not my daily driver just testing )
the rest is very slick and smooth      ( there are 2 ways to update from settings, and about ,i guess one will be removed )
Awesome. Is there a changelog somewhere? Wanting to keep an eye out for GPS working
(05-05-2020, 04:06 PM)Luke Wrote: Here are the UT images you should use from now on, as these images include OTA updates (obviously, get the latest one).
I had to switch the update channel to "pine" for the phone to find the update.
But now, my phone does not work anymore Sad
When powering ON, I get the notification LED red then green. Then I can see the Pine64 logo. Then... a black screen.
Maybe that was not the right update channel ?
i did the same to find the update ,switched to pine . it worked great.for me ,nice install screen ,great work #7 upto #9
not able to get sim /apn working AT&T (consumer cellular ) tried 2g/3g and 2g/3g/4g/ settings ,apn settings go in looks like they are saved, but greencheck marks are,blanjk when rebooted ,
anyone else having issues.
this is not my daily driver
Similar issue on Verizon. APN seems saved but won't check so no calls or texts. Also, "Internet/MMS" APN never works, have had to save "internet" and "mms" as separate APNs.
(05-08-2020, 01:01 PM)brb78 Wrote: Similar issue on Verizon. APN seems saved but won't check so no calls or texts. Also, "Internet/MMS" APN never works, have had to save "internet" and "mms" as separate APNs.
retried with #11 still no network
  Ubuntu Touch on Pine64 Rondarius 11 17,126 10-11-2023, 12:36 PM
Last Post: Rondarius
  Ubuntu Touch vs Standard Pinephone OS MarsColonist 8 20,166 06-26-2023, 07:50 AM
Last Post: gregb49
  Reinstall Ubuntu Touch on PinePhone with 10 drives? Peter Gamma 4 9,193 05-24-2022, 06:42 AM
Last Post: Peter Gamma
  UB Touch build with debos layton-dev 0 7,475 04-23-2021, 08:12 AM
Last Post: layton-dev
  Whats the latest with UB touch? Cree 9 19,047 03-11-2021, 10:59 AM
Last Post: andybleaden@gmail.com
  UT move to Ubuntu 20.04 Concrete_panda 2 8,802 11-24-2020, 12:43 PM
Last Post: DrewTechs
  Horrible energy consume on Pinephone/UB-Touch firefox-58 9 19,374 10-15-2020, 12:28 PM
Last Post: plainenough
Star Updates stuck on stable channel. Cree 6 13,249 10-04-2020, 11:26 AM
Last Post: Giiba
  Pinephone 3G Bluetooth Working Pretty Well With Latest Mobian Updates rmcg 0 4,348 09-27-2020, 10:22 PM
Last Post: rmcg
  How to enable SSH on UBPorts Ubuntu Touch? eaglecup 12 33,629 09-15-2020, 03:42 PM
Last Post: voidmain
