The first time my phone suspended it wouldn't wake up. The screen lit up, but remained black.
The second time it came back up but mobile data wasn't working.
Both were fixed by a reboot.
I did not flash a new image. I updated the kernel and u-boot per your instructions. If this keeps happening I will flash the new image and see if that changes something.
(04-22-2020, 04:10 AM)Boern Wrote: The first time my phone suspended it wouldn't wake up. The screen lit up, but remained black.
I think I've seen the same problem with s2idle, which is used by default, if the suspend lasts more than 3 minutes.
The systemd-watchdog is killing the user session because it thinks it has not responded for more than 3min.
My hacky workaround was to disable the watchdog:
sudo cp /lib/systemd/system/systemd-logind.service /etc/systemd/system
and set RuntimeWatchdogSec=0 in /etc/systemd/system/systemd-logind.service.
Hope this helps! Also, I have not seen this happening with deep sleep.
(04-21-2020, 06:14 PM)a-wai Wrote: ...
 as I already have a huge backlog, ...
Any low hanging fruits a noob with too much time on their hands might be able to tackle? Smile
(04-22-2020, 02:18 AM)l_gyuri Wrote: The default scale can be set in '/usr/share/phosh/rootston.ini' in the '[outputBig GrinSI-1]' section.
Actually, you should create/edit '/etc/phosh/rootston.ini' if you want your config to persist across updates.
(04-22-2020, 06:12 AM)dodoeg Wrote: I think I've seen the same problem with s2idle, which is used by default, if the suspend lasts more than 3 minutes.
Thanks for the feedback, that should really help indeed!
(04-22-2020, 03:18 PM)devrtz Wrote: Any low hanging fruits a noob with too much time on their hands might be able to tackle? Smile
@devrtz might be, it depends on your skills and/or things you wish to learn (Debian packaging, Rust programming, C/GTK tinkering...)
Feel free to send me a PM to discuss this Smile
(04-21-2020, 06:14 PM)a-wai Wrote: ......
(04-21-2020, 03:50 PM)pjsf Wrote: ... If you install the screen resize utioity and set it to 1.75.  ...
... I'm considering setting a scale factor of 1.8 by default (instead of 2 currently),... but I'd be interested in knowing what others think about that.
My vote is for 1.8. 1.75 leaves an artefact line across the bottom of my screen occasionally. 1.8 is fabulous in that the entire entry line in Telegram is visible after you raise the keyboard - was always slightly covered before when the 'old' default was 2.
Is anyone else having problems getting mobile data to work? I suspect some kind of modem regression as in general I have not had problems previously?
Right now I spent nearly 60 minutes trying to connect to mobile data without success. I have 2 SIMs on different networks both of which previously worked in my PinePhone, both of which still work in another handset
All of which is very frustrating as I think I have hotspot working: the last thing I did was try tweak a parameter to check the minimal changes needed before posting a "how-to"!
Just locked my screen in landscape mode and now can't get back in. Supposedly it's fixed https://source.puri.sm/Librem5/phosh/issues/73.
Can we get an update with this fix in?
Well, the fixes mentioned in the link are already included since phosh-0.1.7 (we're using 0.2.2)
I suggest you re-open the issue (or create a new one)
How do you turn "deep sleep" on? I'm a noob so sorry about that....
(04-24-2020, 12:58 PM)a-wai Wrote: Well, the fixes mentioned in the link are already included since phosh-0.1.7 (we're using 0.2.2)
Hmm, I tried it on Pureos and there the lockscreen is always shown in portrait mode.
purism@pureos:~$ apt-cache show phosh Package: phosh Version: 0.2.2 Installed-Size: 930 Maintainer: Guido Günther <agx@sigxcpu.org> Architecture: arm64 Provides: notification-daemon, polkit-1-auth-agent Depends: dconf-gsettings-backend | gsettings-backend, libc6 (>= 2.17), libcairo2 (>= 1.2.4), libfeedback-0.0-0 (>= 0.0.0+git20200305), libgcr-base-3-1 (>= 3.8.0), libgcr-ui-3-1 (>= 3.8.0), libgdk-pixbuf2.0-0 (>= 2.22.0), libglib2.0-0 (>= 2.53.2), libgnome-desktop-3-17 (>= 3.17.92), libgtk-3-0 (>= 3.21.5), libhandy-0.0-0 (>= 0.0.11), libnm0 (>= 1.0.0), libpam0g (>= 0.99.7.1), libpolkit-agent-1-0 (>= 0.99), libpolkit-gobject-1-0 (>= 0.94), libpulse-mainloop-glib0 (>= 0.99.1), libpulse0 (>= 0.99.1), libsecret-1-0 (>= 0.7), libupower-glib3 (>= 0.99.4-3~), libwayland-client0 (>= 1.9.91), fonts-lato, gsettings-desktop-schemas Recommends: feedbackd, iio-sensor-proxy, gnome-session, phoc Description-en: Pure Wayland shell for mobile devices Phosh is a simple shell for Wayland compositors speaking the layer-surface protocol. It currently supports .  * a lockscreen  * brightness control and nighlight  * the gcr system-prompter interface  * acting as a polkit auth agent  * enough of org.gnome.Mutter.DisplayConfig to make gnome-settings-daemon happy  * a homebutton that toggles a simple favorites menu  * status icons for battery, wwan and wifi . If you're not working on a Wayland compositor then this package is likely not very useful for you. Description-md5: 71901781bfed9e3eca07805f7cfdb1c6 Homepage: https://source.puri.sm/Librem5/phosh Section: x11 Priority: optional Filename: pool/main/p/phosh/phosh_0.2.2_arm64.deb Size: 208960 SHA256: c39c835dc082f9a0c66cd5df3098448ece21c59cac6085b4d5d554d1905e5025 Package: phosh Version: 0.1.8 Installed-Size: 818 Maintainer: Guido Günther <agx@sigxcpu.org> Architecture: arm64 Provides: notification-daemon, polkit-1-auth-agent Depends: dconf-gsettings-backend | gsettings-backend, libc6 (>= 2.17), libcairo2 (>= 1.2.4), libgcr-base-3-1 (>= 3.8.0), libgcr-ui-3-1 (>= 3.8.0), libgdk-pixbuf2.0-0 (>= 2.22.0), libglib2.0-0 (>= 2.53.2), libgnome-desktop-3-17 (>= 3.17.92), libgtk-3-0 (>= 3.21.5), libhandy-0.0-0 (>= 0.0.12), libnm0 (>= 1.0.0), libpam0g (>= 0.99.7.1), libpolkit-agent-1-0 (>= 0.99), libpolkit-gobject-1-0 (>= 0.94), libpulse-mainloop-glib0 (>= 0.99.1), libpulse0 (>= 0.99.1), libsecret-1-0 (>= 0.7), libupower-glib3 (>= 0.99.4-3~), libwayland-client0 (>= 1.9.91), fonts-lato, gsettings-desktop-schemas Recommends: gnome-session, phoc Description-en: Pure Wayland shell for mobile devices Phosh is a simple shell for Wayland compositors speaking the layer-surface protocol. It currently supports .  * a lockscreen  * brightness control and nighlight  * the gcr system-prompter interface  * acting as a polkit auth agent  * enough of org.gnome.Mutter.DisplayConfig to make gnome-settings-daemon happy  * a homebutton that toggles a simple favorites menu  * status icons for battery, wwan and wifi . If you're not working on a Wayland compositor then this package is likely not very useful for you. Description-md5: 71901781bfed9e3eca07805f7cfdb1c6 Homepage: https://source.puri.sm/Librem5/phosh Section: x11 Priority: optional Filename: pool/main/p/phosh/phosh_0.1.8_arm64.deb Size: 188656 SHA256: 1a58c186b34afdb1343ac68943c5a2a9add292a6cb8c40950858bcaf2eb9730b
  Mobian image for the PinePhone Korfou 2 1,992 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,029 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,816 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 353,754 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,453 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,267 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,620 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,610 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,830 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,089 01-08-2024, 02:50 PM
Last Post: ERPlegend
