RPro Image Suggestions
Hi all,
As an existing owner of Pine64s and a Rock64, I have finally decided to take the plunge with a RockPro64.  It is on its way, and I am pondering OSes.  As I recall, original Pine64 and Rock64 builds were a bit mixed and so I wanted to reach out to ask the experts about the build that I should consider. (I have the most experience with Ubuntu/Armbian, and my use case is a headless Linux server using a minimal distribution.)  My current ideas are:
Ubuntu 18.04
Armbian
DietPi
What do you folks think of these?  Is one better than the others from a reliability on the RPro standpoint? Is there anything else that I should consider?
TIA
I can't answer your questions as I have no meaningful experience of armbian or dietpi. Certainly I am happy with my installation as per my sig: it runs pretty stable and suitably low resource usage. So Ubuntu minimal is def worth being on your list imho.
I did try recently Manjaro ARM and postmarketOS (from pinebook pro) in a futile attempt to get a v5 kernel. Basically with both I had problems fairly quickly to get the functionality I need and couldn't resolve them so I am still on Ubuntu.
(04-14-2020, 04:51 PM)dukla2000 Wrote: I can't answer your questions as I have no meaningful experience of armbian or dietpi. Certainly I am happy with my installation as per my sig: it runs pretty stable and suitably low resource usage. So Ubuntu minimal is def worth being on your list imho.
Thank you.  It sounds like you have had a great experience with Ubuntu.  I will probably start with that unless I hear strong recommendations to go another direction.
For headless i would suggest https://github.com/ayufan-rock64/linux-b...m64.img.xz
Debian Buster 10.3 with kernel 5.6. And booting from an PCIe NVMe SSD Big Grin
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(04-16-2020, 08:44 AM)Bullet64 Wrote: For headless i would suggest https://github.com/ayufan-rock64/linux-b...m64.img.xz
I would be open to this.  However, I notice that it is clearly stated as a pre-release build with lots of verbiage around stability and testing.  I ran something like this with my Rock64, and encountered trouble upon upgrading that brought the system down. As a result, I was not all that comfortable with stability of pre-release builds.  I take it your experience has been different? Do you upgrade to every pre-release build?
  Debian image configured for USB-C OTG? djonathan 2 6,362 01-06-2022, 03:09 AM
Last Post: susy1075
  First Lakka image for ROCKPro64 Ntemis 12 33,245 09-18-2020, 01:50 AM
Last Post: Wizzard
  Recalbox Image is available Luke 0 3,595 03-06-2020, 05:28 PM
Last Post: Luke
  NixOS image with panfrost Thra11 4 10,039 11-03-2019, 01:13 AM
Last Post: kolbycrouch
  computelibrary build issue with latest ubuntu 18 image rahulsharma 0 3,022 07-08-2019, 09:25 AM
Last Post: rahulsharma
Question freeze on multiple image from wiki Slam 6 12,294 05-12-2019, 04:08 PM
Last Post: Slam
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 3,678 02-26-2019, 05:14 PM
Last Post: caillou
  debian image rocksa 2 6,382 02-08-2019, 09:53 AM
Last Post: rocksa
  LibreELEC Beta image (04/01/2019) Luke 0 3,504 01-10-2019, 08:05 AM
Last Post: Luke
  Not booting with debian 0.7.7 image Bluetexon 0 2,741 11-28-2018, 01:40 PM
Last Post: Bluetexon
