debian image
Hello.
I hot a 4g rockpro64 and i want a full working debian image.
I have downloaded a debian stretch image listed in wiki but the graphics do not work.
[   306.570] (EE) armsoc: module ABI major version (20) doesn't match the server's version (23) [   306.570] (II) UnloadModule: "armsoc" [   306.570] (II) Unloading armsoc [   306.570] (EE) Failed to load module "armsoc" (module requirement mismatch, 0) [   306.570] (EE) No drivers available. [   306.570] (EE)
Also i want the source for kernel (i want a fresh kernel) because i want to compile an preemt rt kernel
Where can i download a recent image like this ?
(02-07-2019, 06:36 AM)rocksa Wrote: Hello.
https://github.com/mrfixit2001/debian_builds/releases
also this image has problem does not work right the graphics
[ 14.705978] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[ 14.705989] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[ 14.705997] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[ 14.706003] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[ 14.706010] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[ 14.706017] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
firefox crashes chromium crashes
  Freezes and kernel panics with Debian trixie jssfr 4 4,073 04-15-2026, 06:48 PM
Last Post: prahal
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,403 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 3,062 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,135 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 6,535 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 6,362 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 7,625 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 18,055 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,679 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,879 09-30-2021, 11:54 AM
Last Post: publiclewdness
