freeze on multiple image from wiki
Question
I just received my board and tested a few linux images (all the ones with a desktop) but faced the same issue with every single one. the OS would randomly freeze when I use it. I assumed it was caused by asking too much so I installed the fan service found on the forum and made sure to do basic tasks but it keep freezing. If I leave the board running without doing anything it seem to be fine though.
I have the full NAS set (from the pine shop):
- RockPro64 (4gb)
- NAS case
- PCI E 2x SATA
- 30cm headsink
- Case fan
- 32Gb SC / 32 Gb EMMC
- Air Mouse
- ROCKPro64 12V 5A power supply
I think I listed it all.
I have plugged everything so the issue could be the HDD pulling too much power though as I don't do anyrthing with them other than having them plugged I guess this is not the issue.
Have anyone faced a similar issue? Any expert that would know where to check what is going on? I have some programming experience but i'm new to linux!
My current project is to make a media player / NAS connected to a projector.
Thank you for your help & Time!
Slam
From testing and using the board a little more, it appear that the board can run fine for hours as long as I'm not browsing.
If I have FF running (With DietPi) or Chromium running (with armbian, or other desktop images) the screen will freeze at some point (even if I'm active on a terminal typing commands and only have 1 tab open). The tab(s) are generally only loading the forum here so nothing very demanding like youtube would be.
I'm wondering if anyone here is using the RockPro64 as a desktop yet and can run a browser with no issues?! If so how did you manage!
Edit: The freeze is global as even remote SSH or Samba access goes boom!
(05-09-2019, 02:02 PM)Slam Wrote: Edit: The freeze is global as even remote SSH or Samba access goes boom!
You should contact sales@ as the problem you are having shouldn't be happening...
I have similiar problems. Desktop freezes as soon as a SATA HDD is mounted but I thought it was because of some issue with Pulseaudio.
It is ... still working on it.
Thank you for pointing that Sasan I was not expecting this to be the issue. I'll test that tomorrow to see if I have issues when I remove the PCIe SATA card.
Is there alternatives to Pulseaudio? I assume this take case of the audio on the board, would there be any alternative for sound on HDMI?
Thank you for pointing out this! I tested my card without the PCIe card and could indeed run video / youtube / multiple programs with no issues.
I found this post that explain how to remove pulseaudio and still have sound through HDMI so I'm now testing is the SATA PCIe connected again work but it does look promising (running youtube while typing this).
  OpenMediaVault: link from wiki or Armbian? Goffi 0 2,847 02-10-2022, 03:57 AM
Last Post: Goffi
  Debian image configured for USB-C OTG? djonathan 2 6,346 01-06-2022, 03:09 AM
Last Post: susy1075
  First Lakka image for ROCKPro64 Ntemis 12 33,190 09-18-2020, 01:50 AM
Last Post: Wizzard
  RPro Image Suggestions jl_678 4 9,301 04-16-2020, 09:06 AM
Last Post: jl_678
  Recalbox Image is available Luke 0 3,586 03-06-2020, 05:28 PM
Last Post: Luke
  NixOS image with panfrost Thra11 4 10,010 11-03-2019, 01:13 AM
Last Post: kolbycrouch
  computelibrary build issue with latest ubuntu 18 image rahulsharma 0 3,015 07-08-2019, 09:25 AM
Last Post: rahulsharma
  System freeze... Faradn 0 2,715 06-09-2019, 08:30 AM
Last Post: Faradn
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 3,675 02-26-2019, 05:14 PM
Last Post: caillou
  debian image rocksa 2 6,363 02-08-2019, 09:53 AM
Last Post: rocksa
