postmarketOS/Alpine edge image for the Pinebook Pro
#21
Is there a chance of a 'regular pinebook' (no pro) image anytime soon? I think it would be nice to have a lightweight alternative for that less power device.
Thanks!
(04-06-2020, 04:48 PM)MartijnBraam Wrote: I'm working on the sleep support, I have a 5.6 kernel built locally that improves a few details. for sleep the current workaround is making it use s2idle instead of deep sleep.
You can do `echo s2idle | sudo tee /sys/power/mem_sleep` to set the default sleep mode to s2idle but it isn't persistent across reboots.
It working perfectly, thank you very much Smile
I just did an alias in my .zshrc to quickly apply this workaround.
To be honest, I'm using only postmarket since 2 days and I think I will keep it for my main OS.
Just I have a strange thing about emmc install (dd on emmc from emmc to usb adaptor).
In my case it's unusable, because on boot nothing responding, I'm on login page but keyboard/trackpad and usb are disabled.
postmarket didn't crash, if I wait some minutes, screen fade to black (screensaver), but I still can't do anything.
It's not a big problem, currently I only use sd card  but but I just want to say it Smile
Hmm that's weird, I haven't flashed it to eMMC yet to test. for the workaround I added the alpine sysfs thing to automatically set s2idle in my new image. will publish that one soon.
(04-07-2020, 12:50 AM)e-minguez Wrote: Is there a chance of a 'regular pinebook' (no pro) image anytime soon? I think it would be nice to have a lightweight alternative for that less power device.
Thanks!
In theory that one is pretty easy to support since we already have the A64-lts, pinetab and pinephone. The reason it's not in there yet is that I don't have a test device for it and nobody with the og pinebook made the port yet in pmos. It's probably a easy port to make so you could try it Smile
Thank you for making pmOS on the PBP possible :)
However, is there any ETA for this weird eMMC issue that @tuxfanou described (#22)? I would love to help debugging in case it's needed.
It's just that I am unsure whether I should flash it on my SD for now (and maybe putting /home on eMMC)
@bleistift @tuxfanou I haven't been able to reproduce the eMMC issue. Could you get a dump of `logread > log.txt` and upload that?
@MartijnBraam I'm sorry but I can't do it on eMMC because ther is no keyboard, no trackpad and no usb, only screen.
Maybe it's possible to do something with UART console but I don't know how to do.
I just want to add a bug to the list (on sd card) : I can't use only headphones without speakers (both are always active) even if I try to use alsamixer. I can remember Manjaro had the same problem with kernel 5.5 and it has been patched in 5.6 (but I'm not sure) so I presume it's a known issue.
Pinebook pro support is now merged in postmarketOS Smile
(04-14-2020, 04:04 PM)tuxfanou Wrote: I just want to add a bug to the list (on sd card) : I can't use only headphones without speakers (both are always active) even if I try to use alsamixer. I can remember Manjaro had the same problem with kernel 5.5 and it has been patched in 5.6 (but I'm not sure) so I presume it's a known issue.
The pmos build is running 5.6 though, I specifically made an alsa UCM file to make it properly support headphone switching.
(04-20-2020, 07:34 AM)MartijnBraam Wrote: Pinebook pro support is now merged in postmarketOS Smile
Thank you so much for you very hard work !
Can I stay on my current installation with an apk upgrade or is it mandatory to build now myself ? Will you create a new image ?
(04-20-2020, 07:34 AM)MartijnBraam Wrote: The pmos build is running 5.6 though, I specifically made an alsa UCM file to make it properly support headphone switching.
I'm still on 5.5.0-rc3. Will your patch be available without re-flashing sdcard or not ?
Thank you again. Now I don't want to leave pmOS thanks to you (and trying to use it on my old phones/tablets)
I would like to help but I don't know how I can.
You should be able to just upgrade your current system to the stuff that has been merged. It should pull linux-postmarketos-rockchip 5.6 from the postmarketOS repository: http://pkgs.postmarketos.org/package/mas...s-rockchip
It works like a charm !
Thank you very much for information about this package, I just needed to do `apk upgrade -a` instead of `apk upgrade`
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,011 08-09-2025, 06:53 AM
Last Post: Sb2024
  What's a good image to use now? [tutorial help as well] frank_philip 40 17,360 07-18-2025, 07:28 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 10,441 03-28-2025, 10:08 AM
Last Post: DrYak
  PBP does not start from postmarket OS image burnt to sd card zkajdan 21 9,519 03-10-2025, 01:55 PM
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,570 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,032 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,618 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,379 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,177 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,284 12-11-2023, 03:47 AM
Last Post: calinb
