(04-13-2020, 09:19 AM)Luke Wrote: Do you guys have ideas how to make the volume buttons work?
Not really, no.
libinput sees the events, so my guess is there's something missing between phosh and the apps, but I have no idea what that could be...
This phosh issue seems to be related, but I don't know more.
(04-10-2020, 03:30 PM)nas Wrote:
(04-10-2020, 05:31 AM)NotAus1 Wrote: Hi, I try to use PP for connecting to whatsapp (bad word, I know ), navigation and photos. Did not manage to get any of those working yet.
Not a photo and not location via gps. Maybe someone could give a hint, where I could start.
The camera doesn't work currently but whatsapp-web might be possible.
For the maps issue, have you turned on location services in the privacy settings menu?
ok, location service is on. OSMScout-server+pureMaps won't show location. Maybe I have to try gpsd in addition ?
Looks like I deleted my post somehow so here's the short version: you can install anbox and its modules but there appears to be a problem somewhere.
1) install modules
2) sudo apt install anbox
3) download android image and move to /var/lib/anbox/android.img
4) sudo systemctl start anbox-container-manager.service
5) systemctl --user start anbox-session-manager.service
6) anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
[launch.cpp:214@operator()] Session manager failed to become ready
Fixed:
a) make sure to select android.img from android-image-working.tar.gz
b) sudo apt install android-tools-adb
c) adb install random.apk (random android apk files are available online)
d) sudo /usr/share/anbox/anbox-shell.sh (if you need root access)
e) some links to information sources
Hey guys,
is it actually enough to update my phone with
sudo apt update sudo apt dist-upgrade
or do I need to flash a new image regularly?
Best,
Thomas
(04-13-2020, 07:38 AM)a-wai Wrote: A few cosmetic details have changed ("King's Cross" now appears as "Terminal")
Awe - that was a lovely quirky touch Sad
(04-13-2020, 07:38 AM)a-wai Wrote: Finally, thanks to @rico we now have a network connection and serial console through USB! All you have to do to enable it is install the pinephone-devtools package, then reboot.
You folks are fantastic - thank you Big Grin Big Grin Big Grin
(04-13-2020, 08:15 AM)rico Wrote: ...
And to all my PinePhone friends, keep in mind it's still in development stage Wink
Spoilsport Wink In my day software was production ready if it compiled! Ask young Mr Gates about MS-DOS!
(04-13-2020, 02:45 PM)Concrete_panda Wrote: Hey guys,
Best,
Thomas
Normally an update/upgrade is sufficient - in this case it was for me. Occasionally @a-wai has flagged a re-install is necessary though.
(04-13-2020, 02:07 PM)nas Wrote: 6) anbox launch --package=org.anbox.appmgr --component=org.anbox.appmgr.AppViewActivity
The logs suggest network bridge or lxc problem - it may be similar to this github issue.
It actually worked for me. I sometimes had scaling issues, where the screen seemed to be a few pixels above the touch input and text input seemed to input weird characters instead of what I typed (equals sign instead of backspace) but I've never had anbox work as good on any device before. Thanks!
So, even though it isn't working for you, we seem to be on the right track.
(04-13-2020, 03:24 PM)Boern Wrote: It actually worked for me. I sometimes had scaling issues, where the screen seemed to be a few pixels above the touch input and text input seemed to input weird characters instead of what I typed (equals sign instead of backspace) but I've never had anbox work as good on any device before. Thanks!
That's good news, care to share a photo?  Smile
I had a similar input issue in retroarch - seems to be a squeekboard quirk.
I guess something is iffy with my setup so I may just need to flash the latest image. Otherwise, this github thread seems pretty close to my problem.
@a-wai this is probably very low on the to-do list, but in pmOS + Phosh build there is a settings option to change the wallpaper ... would be nice to have in this build too.
(04-13-2020, 04:13 PM)nas Wrote: That's good news, care to share a photo?  Smile
I could even set the German language. Of course, now that I want to take a screenshot of it I can't reproduce the bug with the messed up screen placement.
Ah, well, here's anbox running on the pinephone:
.png   2020-04-14-074843.png (Size: 185.46 KB / Downloads: 2,300)
[Image: attachment.php?aid=1772]
And running the calculator app:
.png   2020-04-14-075057.png (Size: 53.76 KB / Downloads: 2,090)
[Image: attachment.php?aid=1771]
Minor  annoyance :
Phone rings on full volume for incoming call,   while already on an existing call.
call waiting normally chirps or beeps when you get a second call.
I have not tried switching to the second incoming call,  ...   has someone else... I am curious  ?
>  Not complaining,   this is as it should be, except for it being a different 'ringtone'... ?
I would rather this than no notification of a second call.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Mobian image for the PinePhone Korfou 2 2,114 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,826 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 75,342 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 358,253 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,569 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,386 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,688 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,658 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,913 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,209 01-08-2024, 02:50 PM
Last Post: ERPlegend
