Well I tried the March 22nd image off a-wai's website both on my SD card and my eMMC. I get the splash screen, it boots, and then once the desktop loads it crashes. I have zero modifications made and I tried to redownload several times.
So I came back and I tried to build it myself today. I had the same issue that the other user @fpb4 said and I use whatever kernel comes with it
*.*.* PinePhone BraveHeart edition w/ distro: Debian + Phosh // GuixOS, Debian, Arch // pocket linux enthusiast // washed up sysadmin *.*.*
(03-27-2020, 05:56 PM)buffer Wrote: Well I tried the March 22nd image off a-wai's website both on my SD card and my eMMC. I get the splash screen, it boots, and then once the desktop loads it crashes. I have zero modifications made and I tried to redownload several times.
hmmm...?
   I am a simple GUI user,  I download,  flash my SD card with Balena Etcher, put the SD card into my phone.
 >   Voice phone calls work both in and out going,
 >   Text works both directions,
 >  Contact book works,
 >   wifi works for surfing,   though the browser is in need of some help, it does 'work'  (no youtube video, yet)
 >  I am having trouble with data,  but that could be a fault with my old recycled sim card, I am waiting for a replacement from AT&T in the mail.
      ( While attempting to connect with data I got message my plan does not include data, but it does, but I do think that message was from the internet)
     ( I believe AT&T is blocking my connection at this point, new sim card will hopefully fix that )
   May not sound like technical advice,  but try holding the power button for a full 4 seconds before releasing it.
    I did have a problem when I held it for 2 seconds, phone started, but not properly..
      Just my experience so far.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
dd should work just as good as etcher.
Has anyone tried earbuds with the built-in microphone? That's all I have, I don't have a headset and I was wondering if it works on images:
1) pre-March 22
2) March 22 or later
Waiting for Monday so I can try a usable image.
BTW I think @bcnaz seems to imply he's been running apt update, I'm installing image from dd every single time.
Hey all! Just thought I'd mention something I've noticed, and this might just be my unit, but who knows. When booting up the PinePhone with the latest Debian Phosh updates, it starts out by making a quiet, but noticeable, high pitched screech that persists until it's plugged in or removed from a charger for the first time after boot and makes that little "click-click" sound. I thought this might just be a weird artifact of me updating my system over and over instead of just reflashing with a new image, so I tried flashing the March 22 image to a new SD card, and it seemed to be fixed, but after updating everything to the latest version, the issue popped back up again. Not sure what's causing that, but I figured y'all might want to know.
(03-28-2020, 04:54 PM)fishbowlkraken Wrote: Hey all! Just thought I'd mention something I've noticed, and this might just be my unit, but who knows. When booting up the PinePhone with the latest Debian Phosh updates, it starts out by making a quiet, but noticeable, high pitched screech that persists until it's plugged in or removed from a charger for the first time after boot and makes that little "click-click" sound. I thought this might just be a weird artifact of me updating my system over and over instead of just reflashing with a new image, so I tried flashing the March 22 image to a new SD card, and it seemed to be fixed, but after updating everything to the latest version, the issue popped back up again. Not sure what's causing that, but I figured y'all might want to know.
I've definitely had that issue too! I have it across operating systems, ever since it came out of the box and I turned it on it does this.
Smile
Wow! Smile
I have my pinephone since 26/03 en started to experiment with various operating systems. I'm really impressed by "debian+phosh". I've flashed it to the emmc of my pinephone with jumpdrive.
And debos-pinephone/build.sh works great to customize some things. Interesting! I've learned a lot new things. (Minor detail, debos-pinephone/build.sh doesn't work when you try to run it from a ZFS partion.)
Thanks!
(03-29-2020, 05:48 AM)janw Wrote: I have my pinephone since 26/03 en started to experiment with various operating systems. I'm really impressed by "debian+phosh". I've flashed it to the emmc of my pinephone with jumpdrive.
Thanks Smile
(03-29-2020, 05:48 AM)janw Wrote: (Minor detail, debos-pinephone/build.sh doesn't work when you try to run it from a ZFS partion.)
That sounds like something you should report to debos upstream Wink
It's sunday, so a new image is available Wink
In addition to what I mentioned in my March 26th post, this image includes firefox-esr (tweaked the best I could to make it usable on the PP) and file-roller (archive manager) as well as a few additionnal tweaks under the hood.
SMS notifications are now enabled by default, but the messages might not appear in the chats list before a reboot.
Please note that, as we switched to Debian testing, it is highly recommended that you install the new image instead of upgrading through apt.
I think it's more a problem to report to ZFS Wink
2020/03/29 18:46:22 bmaptool create debian-pinephone-20200329.img > debian-pinephone-20200329.img.bmap | bmaptool: ERROR: cannot generate bmap for file 'debian-pinephone-20200329.img': the file-system does not support "SEEK_HOLE" and "SEEK_DATA" but only provides a stub implementation 2020/03/29 18:46:22 bmaptool create debian-pinephone-20200329.img > debian-pinephone-20200329.img.bmap | 2020/03/29 18:46:22 Action `Create block map file` failed at stage Postmachine, error: exit status 1
(03-29-2020, 09:49 AM)a-wai Wrote: It's sunday, so a new image is available Wink
No cigar mate - same with the last build (vanilla from your repo, default kernel). Boots, stands by a perfectly visible lock screen, unlock, diplays phosh GUI for a couple seconds and dims to a dark screen (well it seems only to a too low backlight) - pressing power button brings back up a visible lock screen.
Started post Mar 15th build (the last known working).
  Mobian image for the PinePhone Korfou 2 1,992 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,034 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,822 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 353,771 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,454 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,268 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,620 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,610 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,831 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,090 01-08-2024, 02:50 PM
Last Post: ERPlegend
Users browsing this thread: 8 Guest(s)
