Window manager
I've just successfully set up Debian with FDE (https://forum.pine64.org/showthread.php?tid=9467&page=2)
Had some issues with installing window managers although Gnome did install without any issues and the system runs with it.
I have afterwards tried installing both Cinnamon and Xfce with apt along side Gnome and I can log in fine to both Cinnamon and Xfce without issues, but as soon as I hit right click button on the touch pad, I get logged out (or may be it crashes?). Does anyone have any clue what is going on here?
No ideas here? would be greatly appreciated if there were.
(03-23-2020, 05:28 PM)GloriousCoffee Wrote: I've just successfully set up Debian with FDE (https://forum.pine64.org/showthread.php?tid=9467&page=2)
You can try installing a newer Mesa. If you don't want to go through all the steps manually, this script should work:
https://forum.pine64.org/showthread.php?tid=8953
Okay,
what is 'pbp-build' ? It does not exist on a newly installed bullseye with Thompson installer.
EDIT:
So I tried following the script line by line (had to do multiple installs through apt) and I skipped the uninstall part. Now Cinnamon seems to run, it doesn't crash the way it did before. Very happy Smile Many thanks!
pbp-build is the build directory in my script. i use this generally to avoid a conflict with an existing build directory in projects.
Question linuxmint / webapp-manager popinski 2 4,885 10-10-2021, 09:28 AM
Last Post: popinski
  Flickering black window when opening settings Edgars10 0 3,151 06-06-2021, 05:42 AM
Last Post: Edgars10
  Dolphin File Manager Nobot 0 3,127 10-24-2020, 11:07 PM
Last Post: Nobot
Photo Remove activity manager bar on right side of screen - plasma kde motezart 3 7,915 10-20-2020, 10:36 AM
Last Post: motezart
  Wi-fi: "Device not managed" in Network Manager gfoty 5 11,989 03-26-2020, 07:57 AM
Last Post: gfoty
  PBP ARM Processor RECOGNIZED by Default Debian OS Synaptic Package Manager jcj52436999 14 29,828 12-19-2019, 11:28 AM
Last Post: User 6582
