(03-19-2020, 05:40 AM)vinnie Wrote: - the calls work both outgoing and incoming, the audioo is not perfect (but I had launched an AT command with pmos and probably have to launch another one to compress the audio less)
- I can switch between the two speakers during the call
Oh wow, during calls the other person cannot hear me but I can hear them. I can't figure out why! Huh
Did you have to configure anything first? Did they work out of the box?
Did you build the image or download a premade one (if premade, which one?). I would like to know so I can have a phone that has bare minimum functionality. Thanks! Heart
(03-19-2020, 09:29 AM)buskmann Wrote:
(03-18-2020, 03:10 PM)buffer Wrote: tbh it's easier to use Jumpdrive after you build the image on a computer
Do you mean building the image to be the exact size of the drive?
I used Jumpdrive to flash it to the phones internal storage, and the partition is alot smaller then the drive:
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk2      179:0    0 14.7G  0 disk
`-mmcblk2p1  179:1    0  3.7G  0 part /
mmcblk2boot0 179:32   0    4M  1 disk
mmcblk2boot1 179:64   0    4M  1 disk
Lol I just barely managed to type that tiny reply on my pinephone from within Firefox, and got tired...
I'm not sure about the keyboard layout question but I meant building the image on any laptop or desktop instead of on your PinePhone
As for the other errors, you can do <code>apt-cache search sfdisk</code>, and try installing what comes up, maybe you don't have fdisk installed. I know it shows sfdisk which is weird but on my Debian Buster I was able to do it.
Did you run sudo growpart? You'll need sudo for that.
In any case someone has added to the wiki, a much better method: https://wiki.pine64.org/index.php/PinePh...disk_space
Hohoho, time for me to rebuild and resize with the cleaner method. Just in case I )$*$*ed anything up that way.
*.*.* PinePhone BraveHeart edition w/ distro: Debian + Phosh // GuixOS, Debian, Arch // pocket linux enthusiast // washed up sysadmin *.*.*
[/quote]
[/quote]
Well this is starting to be a bit embarrassing.. Sudo was the solution. Haha..
Thanks a lot for the help! Big Grin
About hotspot :
I'm still working on, i had a kernel issue.
a-wai explained how fixing this (thanks again)
Current hotspot needs iptables and dnsmasq, we'll add this when everythings gonna be ok.
Work In Progress.
(03-19-2020, 05:40 AM)vinnie Wrote: ...
Trouble:
- mobile data not working, if I activate the switch the call signal goes away too (do I have to give some command at to activate the modem?)
It seems to me mobile data stability has regressed significantly. I am virtually unable to get it to work myself now whereas a week or so ago it just worked out of the box from Settings. Now disabling WiFi (which is useful to establish if mobile data is working) means the phone has a tendency to enable Airplane mode - you have to keep checking that is not the case.
Something else I have noticed is that 1 of my SIMs (3 UK) seems to have onboard APN definitions and is more likely to work. The other (Virgin UK) does not so I can define goto.virginmobile.uk as the APN but it seems to be less happy to actually try connect for mobile data.
I am not sure if this is something about power saving on the modem - my display spends a lot more time showing 3G connection (despite the fact I can throw a stone at a 4G mast!) Forcing the network selection to 4G seems to keep the display (top status line) consistently on 4G even when there is no connection!
I struggle to define when and what things went backwards as the SIM I mostly have in my PP does not consistently have any data allowance.
At the moment my best guess is the root cause is disabling WiFi is not handled gracefully: if I enable WiFi the mobile data status seems stable and as expected but of course can not be tested!
~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
      valid_lft forever preferred_lft forever
3: wwan0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN group default qlen 1000
   link/none
   inet 10.101.207.56/28 brd 10.101.207.63 scope global noprefixroute wwan0
PS - it seems if I start with WiFi enabled, setup mobile data, then disable WiFi, mobile data works fine until I reboot.
  Would it be OK  to install Synaptic ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(03-20-2020, 03:57 PM)bcnaz Wrote:   Would it be OK  to install Synaptic ?
You can install it, but it wont run on Wayland Big Grin
   AWW !
            I am Disappointed.
                     but,  Thanks for the response
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I installed MATE desktop and would like to try it. But what command do I need to switch from PHOSH to MATE?
Many thanks.
Are you using auto-log-in ?
Seems to me when using GUI, you can make the choice at the log-in screen ... ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(03-20-2020, 05:27 PM)bcnaz Wrote: Are you using auto-log-in ?
In Settings, "Automatic Login" is greyed out and cannot be enabled (unless there is an unlock button somewheree off the screen).
  Mobian image for the PinePhone Korfou 2 1,905 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,469 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,471 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,019 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,372 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,139 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,548 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,542 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,729 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,025 01-08-2024, 02:50 PM
Last Post: ERPlegend
