Arm supported software
Hi all,
I got my pinebook pro a few days ago and its been amazing. Sadly thou i can't find a predefined list of arm supported apps. Does visual studio work on arm? I also can't seem to get play.spotify.com working both on chromium and firefox. (Something about drm.)
I've installed the latest version of Manjaro KDE and its something. Sadly I can't see where i can add value. My background is in product/digital design so i know how to design and not build  Big Grin
Maybe i missed the supported arm software wiki page.
Thanks for reading.
The DRM is likely Google's Widevine (the same DRM required to watch Netflix.) Unfortunately, Google has not made a Widevine package for the aarch64 userspace (which Manjaro and most other OSes run on the PBP.) There are CLI Spotify-connectable apps that you can use instead.
  Error trying to update Manjaro software boosterh 5 9,318 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 217,761 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 5,796 11-25-2021, 05:59 AM
Last Post: mexsudo
  Running x86 software GloriousCoffee 19 40,084 02-15-2021, 11:43 AM
Last Post: jiyong
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 16,875 09-29-2020, 07:55 AM
Last Post: hmuller
  Software Compatibility, If on Pi then? chetchinglo 5 11,402 06-06-2020, 07:11 PM
Last Post: chetchinglo
