Gnome-shell is a touch unstable still for me
Hi all,
I'm finding there are things I do with Gnome-shell on Manjaro (I installed it by hand from the KDE installer for the internal drive) that will crash the shell.  Some are easy (trying to change the background image) and some are more complex (turning on the dash to dock extension).
Any suggestions on some tweaks I might have missed that will help the out?  If not, what troubleshooting data can I gather to help diagnose and correct the problem?  I'm like 4th and inches from having this machine set up exactly like I would like it so a big THANK YOU to everyone for their hard work!
Another alternative might be an Ubuntu installer for the internal drive.  That's probably closer to my final desktop than anything, although I've enjoyed being back in the arch world...
Thanks again!
I can't recall if it was pushed to the stable repos, as I updated to it from unstable, but are you running Gnome 3.36?
Thanks for replying. i'm running 3.35.91 it looks like.
- B
Try seeing if you can update to 3.6
Is there a trick to force it to use 3.36? Also a regular "sudo pacman -Syu" isn't working for me (see my other thread).
Thanks.
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,238 08-09-2025, 06:53 AM
Last Post: Sb2024
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,760 05-31-2024, 09:42 AM
Last Post: SynthGal
  Manjaro Gnome 22.06 pamac update fail/soft-bricked-OS u974615 5 7,724 08-21-2022, 12:00 PM
Last Post: u974615
  Manjaro Gnome on Pinebook Pro Review! - My New Favourite Pinebook Pro Distro! ImmyChan 0 3,727 02-18-2022, 12:59 PM
Last Post: ImmyChan
  Debian/unstable SD card rescue image vajak 4 9,324 10-28-2021, 02:53 PM
Last Post: vajak
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 4,546 07-13-2021, 10:37 PM
Last Post: pjsf
Rainbow Armbian Groovy/Bullseye with Gnome clover 10 20,827 12-27-2020, 04:10 PM
Last Post: bus-error
  Best Gnome distro for PBP? Upokupo 2 7,215 11-26-2020, 11:51 AM
Last Post: clover
Information How to make the Manjaro Gnome image update TDC_PBP 2 7,043 07-13-2020, 02:24 PM
Last Post: TDC_PBP
  Ayufan's Ubuntu Focal Gnome (20.04) mlentink 24 45,544 07-02-2020, 11:04 AM
Last Post: mlentink
