Slackware (aarch64) on the Pinebook Pro
Hi Folks,
After purchasing a Pinebook Pro recently I was faced with the fact that there was no out-of-the-box Slackware (or derivative of thereof) installer available.
After spending some time interacting with forum user mara/sndwvs at LinuxQuestions ( https://www.linuxquestions.org/questions...?p=6093972 )
I managed to cross-compile (on x86_64) an installer file system image with his script that's available at https://gitlab.com/sndwvs/slackware_arm_build_kit
Unfortunately the installer image doesn't seem to work: it doesn't boot on Pinebook Pro for some reason.
What I see is that when the micro SD card is inserted, and the system powered on, the screen stays blank, and seemingly nothing happens.
How could I debug this boot-related problem? Do I need the serial cable to do that, or can it be debugged some other way too?
Thanks in advance!
Best Regards,
János
Hi Janos, any news?
Did you succeed and made your image booting?
I'm not that experienced in debugging such systems. But I'm curious if slack is possible.
Best regards
zedr0k
(02-28-2020, 11:33 AM)zedr0k Wrote: Hi Janos, any news?
Best regards
zedr0k
No, unfortunately. I haven't been able to make it boot with the slarm64 installer images.
(03-03-2020, 04:50 AM)wowbaggerHU Wrote: No, unfortunately. I haven't been able to make it boot with the slarm64 installer images.
Another update: The installer images look okay, but the different kernels are stuck during startup.
For more information please see: https://www.linuxquestions.org/questions...ost6099060
Best regards
zedr0k
We finally managed to create a working bootable image of the slarm64 installer. For details please see:
https://www.linuxquestions.org/questions...ost6099406
Hi Janos,
great news. I tried the image and it works fine.
Thank you. Good to have slack on the pinebook pro
Best regards
zedr0k
Awesome stuff! You should add this to the PBP Software Releases wiki page.
Yes, it is very nice, speedy, I started with slackware a long time ago
It is an IMMENSE amount of work to get X running, and imperfectly
Maybe a template? Thanks for your work
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,893 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 10,248 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,483 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 2,724 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,980 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,531 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,205 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,107 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,194 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 134,011 12-08-2023, 11:25 PM
