Kali Linux for Pinebook Pro
#21
Think they mixed up some stuff.
Kali 2020.1a has a bug fix for x11. PBP version seems to be 2020.1 without the patch. After updates mine broke with the same x11 bug. As WDT suggested it's still using the older user/pass.
Im re-writing my SD at the moment. When it's done I'm looking into this: https://bugs.kali.org/view.php?id=6053
[Edit] Just installed "xserver-xorg-input-all" but kali-menu seems to be broken? Il'l try apt-get upgrade and reboot Smile
@Tazdevl
Yes indeed,, complains about a missing directory, which does not exist
So, 1st thing, install something simple*, notice error msg,,, mkdir /usr/share/........
I don't know if this is good enough, but at least shuts up error msg
(*like perhaps "ne", will not install anything else)
--edit--
All the fs errors were from resize2fs, nothing to do with kali
purge kali-undercover,, an update locks computer, repeatedly
Had to remove from status to finish update
Did the folder fix but no real progress here, updates don't work. It hangs on kali-undercover
[edit] slow on waking up... I'll try removing undercover
[edit1 ]sudo dpkg --remove --force-remove-reinstreq kali-undercover helps a lot. But ffs, how many times can you write dpkg wrong?
Looks like 2020.2 version is available. I am still waiting for my pro machine. Can someone report how it works and if any issues?
https://www.offensive-security.com/kali-...rm-images/
https://www.kali.org/news/kali-linux-2020-2-release/
I have it running on a micro SD.
Now you have to login with kali/kali.
Audio is working (didn't work with root in the previous version).
First time it still booted Manjaro from the eMMC, but after a restart it booted up.
(05-13-2020, 05:22 AM)jiyong Wrote: I have it running on a micro SD.
Hi all,
I have it running on a micro SD and I have tried to write the image on the emmc but it looks like I have done something wrong. Should I try with the dd command with unmounted emmc? I send you a screenshot showing fdisk -l info.
I an a newbie with Kali Linux but I am trying to learn.
Thanks, happy and healthy hacking!
Ricardo
.png   Screenshot_2020-05-15_13-47-31.png (Size: 67.7 KB / Downloads: 943)
Hi all,
Ricardo
You need to edit the /etc/default/u-boot and /boot/extlinux.conf to match the emmc.
My recommendation is to use UUIDs instead device names.
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
Hi all,
Ricardo
Hi Miguel,
thanks for the information. I will try to find the way to make this changes.
Happy and healthy hacking!
PS: Miguel, parece que tu tambien eres castellanoparlante. Un saludo desde Alemania!
Ricardo
Hi all,
Ricardo
Hi Miguel,
Ricardo
https://gitlab.com/kalilinux/build-scrip...issues/180
Basically read that issue for instructions.
(En realidad me llamo Edu! Saludos desde España Big Grin)
Hi again,
I will give it a try.
Los pseudonimos son una buena idea en la red!
Acabo de ver que no es un pseudonimo, sino que las prisas me hicieron convertir tu apellido en nombre y ademas leerlo mal :-P
Hi again,
I have tried this but i have no output from command blkid/dev/mmcbl2p2
I will continue searching. I have forgotten to tell that I was able to boot from the emmc but then I had no network a was not able to activate it.
Best regards
  Boot Order in Pinebook Pro food 12 19,114 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 6,505 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,239 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 3,405 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,435 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,012 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,651 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 4,118 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,760 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,472 03-31-2024, 10:11 AM
Last Post: u974615
