Wifi Module
So I've got my system up and running with Android, and I cant figure out how to get the wifi to work. Maybe i've installed it wrong. You only have to connect the module to the board right? Also the cord thing looks like it might be a sticker? What sup with that?
(04-14-2016, 08:44 PM)Anunnaki Wrote: So I've got my system up and running with Android, and I cant figure out how to get the wifi to work. Maybe i've installed it wrong. You only have to connect the module to the board right? Also the cord thing looks like it might be a sticker? What sup with that?
I had it in backwards. Posting from the device.
All's well that ends well Smile
Anunnaki - I still have not seen a reply from anyone to your question of what is the "cord thing" with what appears to be a sticker  and what it is for.  Also, when I opened my shipment bag, in addition to my Pine A64 and WiFi / Bluetooth module there was a very small button switch that looks like a toggle on and off. Was this a mistake, and if not what is it for?  I will attach pictures once I get home from work.
The "sticker on a cord" is actually an extra wifi antenna, which can be mounted on or outside you case.
I am not sure but I think that there's a builtin antenna on the circuitboard (or within the wifi chip) but with that antenna properly connected (through the very small uFL connector) it should improve your wifi reception.
(04-18-2016, 08:36 AM)Tommy_2Tall Wrote: The "sticker on a cord" is actually an extra wifi antenna, which can be mounted on or outside you case.
There is no builtin antenna on the circuit board, we prefer to use external antenna which can easily fix to good location that yield better wifi performance.
  [split] Better WiFi/BT module? moriel5 3 10,638 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,809 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,430 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,915 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,886 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,603 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,882 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,153 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
