#41
(02-26-2020, 09:57 AM)harvey186 Wrote: For reproduce, install an app like seafile or nextcloud (any app which is NOT activating the online keyboard).
Ok, so it seems it does so for any Qt-based app (tried also with deepin-calculator and kcalc), that's interesting for sure!
Digging a bit I found this related thread, which looks like this could be related to how Xwayland and squeekboard (fail to) interact.
Anyway, you could ping them and share the details of your bug, then wait for the fix...
nas Wrote:The mac address appears to change after every reboot. Found similar behaviour mentioned here but different chipset not sure if it's relevant.
That shouldn't be (at least with the latest images), can you share your dmesg log?
#42
New release available! Smile
Version 20200226 has a few more packages and customizations (thanks to @rico for most of these), and this release includes newly-released versions of the following Purism packages:
- phosh v0.2.0
- chatty v0.1.8 (along with purple-mm-sms v0.1.2)
- squeekboard v0.1.9
I also upgraded ModemManager, which improves things a bit, but also comes with a few new bugs... If you experience issues with your modem, here are a couple workaround:
- mobile internet: if you fail to connect to Internet, go to Settings -> Mobile, then turn the "Mobile Data" switch off and on again
- text messages not showing up in "Chats": restarting ModemManager (systemctl restart ModemManager.service) should solve the issue
(02-26-2020, 02:32 PM)nas Wrote: On 20200217 at the moment but will upgrade if that's the problem.
Ok, you got an old on, try with 20200226, this should be a solved issue Wink
#43
built and installed the latest, The led is nice. I'm building with firefox and some of the popups overflow the screen, does anybody have any ideas or pointers on how to fix that?
#44
A lot of apps are overflow the screen. And there is no way to move the window. But I think the dev is working hard on it.
#45
Also having DNS issues with 226 img.
"Err:1 https://deb.debian.org/debian sid InRelease
Could not resolve 'debian.map.fastly.net' Could not resolve 'deb.debian.org'"
Trying to locate the issue, but, alas, I'm just too stupid. Tried changine nameservers in the WiFi... host/name file in /etc look okay. Hmm.
Loving all the other updates though! Thanks and keep it coming! Would also contribute a very modest amount as able to any donation you may set up.
#46
(02-26-2020, 07:27 PM)Beattie Wrote: built and installed the latest, The led is nice. I'm building with firefox and some of the popups overflow the screen, does anybody have any ideas or pointers on how to fix that?
Yes, that's the current problem with desktop apps on phones, most of them don't do well with these tiny screens. That should improve after the Pinephone and Librem5 have reached enough people, but for now the only advice I have is to be patient (or, if you have the skills, try implementing an adaptive UI for your apps of interest Wink )
(02-27-2020, 11:21 AM)parkerwb Wrote: Also having DNS issues with 226 img.
Hmmm, I may have a clue: could you try editing your mobile data connection (something like /etc/NetworkManager/system-connections/<APN name>.nmconnection) and change the dns-priority value to 120?
(I don't have a SIM available to test for now)
#47
The only connection I have in /etc/N..M../sys-cons/ is for my WiFi... nothing for Mobile/modem etc. so no priority value. Still digging around.
GNU nano 4.8        The Land of Make Believe.nmconnection        [connection] id=The Land of Make Believe uuid=6a7a79e0-f728-4c53-965e-90c16566d26f type=wifi interface-name=wlan0 permissions= timestamp=1581090957 [wifi] mac-address-blacklist= mode=infrastructure seen-bssids=C0:3F:0E:BD:E0:88; ssid=The Land of Make Believe [wifi-security] auth-alg=open key-mgmt=wpa-psk psk=blahblah [ipv4] dns=8.8.8.8;8.8.4.4; dns-search= ignore-auto-dns=true method=auto [ipv6] addr-gen-mode=stable-privacy dns-search= method=auto [proxy]
#48
Alright, and you can ping 8.8.8.8 with no losses ? Have you tried getting closer to your hotspot ? (I found my Pinephone has a quite limited wifi range)
What does "nslookup kernel.org" output? (package dnsutils, in case it's not installed)
#49
ping 8.8.8.8 works but not ping google.com - there's a quick fix by reordering the hosts entry in /etc/nsswitch.conf - see first part of this solution.
#50
(02-27-2020, 01:23 PM)a-wai Wrote: Alright, and you can ping 8.8.8.8 with no losses ? Have you tried getting closer to your hotspot ? (I found my Pinephone has a quite limited wifi range)
Yes I can browse website by IP, ping by IP etc. Can't install dnsutils because of the apt resolve error. 'service ModemManager stop' didn't help (thinking maybe apt was trying to use mobile data instead of WiFi and I have no SIM installed). Still playing around, but at a loss and, sadly, no linux expert nor DNS expert.
debian@pinephone:/usr/lib/systemd$ resolvectl status Global       LLMNR setting: yes MulticastDNS setting: yes  DNSOverTLS setting: no      DNSSEC setting: allow-downgrade    DNSSEC supported: yes  Current DNS Server: 192.168.1.1         DNS Servers: 192.168.1.1          DNSSEC NTA: 10.in-addr.arpa                      16.172.in-addr.arpa                      168.192.in-addr.arpa                      17.172.in-addr.arpa                      18.172.in-addr.arpa                      19.172.in-addr.arpa                      20.172.in-addr.arpa                      21.172.in-addr.arpa                      22.172.in-addr.arpa                      23.172.in-addr.arpa                      24.172.in-addr.arpa                      25.172.in-addr.arpa                      26.172.in-addr.arpa                      27.172.in-addr.arpa                      28.172.in-addr.arpa                      29.172.in-addr.arpa                      30.172.in-addr.arpa                      31.172.in-addr.arpa                      corp                      d.f.ip6.arpa                      home                      internal                      intranet                      lan                      local                      private                      test Link 3 (wwan0)      Current Scopes: none DefaultRoute setting: no       LLMNR setting: yes MulticastDNS setting: no  DNSOverTLS setting: no      DNSSEC setting: allow-downgrade    DNSSEC supported: yes Link 2 (wlan0)      Current Scopes: DNS LLMNR/IPv4 LLMNR/IPv6 DefaultRoute setting: yes       LLMNR setting: yes MulticastDNS setting: no  DNSOverTLS setting: no      DNSSEC setting: allow-downgrade    DNSSEC supported: yes  Current DNS Server: 192.168.1.1         DNS Servers: 192.168.1.1          DNS Domain: ~.
(02-27-2020, 02:19 PM)nas Wrote: ping 8.8.8.8 works but not ping google.com - there's a quick fix by reordering the hosts entry in /etc/nsswitch.conf - see first part of this solution.
BOOM! That worked. Thanks for the help! Here's what my nsswitch.conf looks like now.
# /etc/nsswitch.conf # # Example configuration of GNU Name Service Switch functionality. # If you have the `glibc-doc-reference' and `info' packages installed, try: # `info libc "Name Service Switch"' for information about this file. passwd:         files systemd group:          files systemd shadow:         files gshadow:        files # hosts:          files resolve [!UNAVAIL=return] dns hosts:          files mdns4_minimal [NOTFOUND=return] dns networks:       files protocols:      db files services:       db files ethers:         db files rpc:            db files netgroup:       nis
  Mobian image for the PinePhone Korfou 2 1,992 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 71,029 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,816 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 353,754 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,453 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 8,267 02-20-2025, 02:47 PM
Last Post: puffchumpy
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,620 01-15-2025, 08:08 PM
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 3,610 01-02-2025, 12:47 PM
Last Post: zetabeta
  atinout binaries for mobian/debian? NeutralGrey 4 5,830 10-31-2024, 04:16 AM
Last Post: astylethargic
  unofficial kali linux for pinephone help needed pinesmell 5 10,089 01-08-2024, 02:50 PM
Last Post: ERPlegend
