mainline kernel hardware acceleration
collecting information and projects regarding hardware acceleration in mainline kernel, ffmpeg, and vaapi.
STATUS:
drm hwaccel working with hantro (mpeg2, vp8, h264) and rkvdec (vp9, h264 8+10bit, h265 8+10bit)
ffmpeg 4.2.3 with v4l2-request-hwaccel-4.2.2-rkvdec patch working well, except decoders listing is broken (i.e. mpv and others will be broken)
kodi supports all hantro and rkvdec hwaccel, including plugins (youtube and jellyfin confirmed) *see kodi-git thread*
gstreamer supports vp8 and h264 via v4l2codecs in gstreamer-plugins-bad
vaapi hwaccel working with hantro (mpeg2)
firefox 75 supports initial vaapi on wayland, v76 expands vaapi support to all supported codecs, no X11 support
chrome supports vaapi with unofficial patch that will never be upstreamed, but included in some linux distros (fedora, etc.)
PBP-TOOLS
pinebook pro tools, including installation scripts, patches, and configs, now on git. also see forum thread.
https://github.com/xmixahlx/pbp-tools
https://forum.pine64.org/showthread.php?tid=10190
REFERENCES
linux patchwork - linux-media:
https://patchwork.kernel.org/project/linux-media/list/
linux patchwork - linux-rockchip:
https://patchwork.kernel.org/project/lin...chip/list/
libreelec/kwiboo mainline kernel patches:
https://github.com/LibreELEC/LibreELEC.t...ux/default
libreelec/kwiboo mainline kernel testing patches:
https://github.com/Kwiboo/LibreELEC.tv
kwiboo's rockchip-linux repos:
https://github.com/Kwiboo/linux-rockchip/
bbrezillon's rockchip-linux repos:
https://github.com/bbrezillon/linux/
ph5's libva patch:
https://github.com/intel/libva/pull/332
libva-v4l2-request;
https://github.com/bootlin/libva-v4l2-request/
ph5's libva-v4l2-request patches:
https://github.com/bootlin/libva-v4l2-request/pulls
kwiboo's ffmpeg v4l2-request branch:
https://github.com/Kwiboo/FFmpeg/tree/v4...ccel-4.2.2
https://github.com/Kwiboo/FFmpeg/tree/v4...2.2-rkvdec
gstreamer v4l2codecs:
https://gitlab.freedesktop.org/gstreamer...uests/1141
gstreamer vaapi:
https://gitlab.freedesktop.org/gstreamer...quests/171
firefox vaapi:
https://bugzilla.mozilla.org/show_bug.cgi?id=1610199
chrome vaapi:
https://chromium-review.googlesource.com...c/+/532294
https://github.com/saiarcot895/chromium-...an/patches
https://aur.archlinux.org/packages/chromium-vaapi/
OTHER
allwinner cedrus hwaccel project:
https://linux-sunxi.org/Sunxi-Cedrus
LibreElec - Early Mainline Images for <...> RK3399:
https://forum.libreelec.tv/thread/17540-...nd-rk3399/
LibreElec - Not Official LE Version for <...> RK3399
https://forum.libreelec.tv/thread/20823-...28-rk3399/
Armbian - early VPU work:
https://forum.armbian.com/topic/4806-the-vpu-driver/
Armbian - Mainline VPU
https://forum.armbian.com/topic/13622-mainline-vpu/
mpeg2video hwaccel is tested working.
testing requirements:
patched kernel (libreelec; optionally kwiboo v4l2 5.5 wip and rkvdec, plus bbrezillon patches)
patched libva (plus pulls 332,340)
patched libva-v4l2-request (plus pulls 28,29,30)
patched ffmpeg (v4l2-request-hwaccel) -- recommend 4.2.2 or -master
> build with --enable-v4l2-request --enable-libdrm --enable-libudev --enable-pic --enable-shared (plus optional config)
determine video decoder:
dmesg | grep rk3399-vpu-dec
note video device (i.e. /dev/video1)
export variables:
export LIBVA_DRIVER_NAME=v4l2_request
export LIBVA_V4L2_REQUEST_VIDEO_PATH=/dev/video1
vainfo output:
Quote:libva info: VA-API version 1.6.1
libva info: User environment variable requested driver 'v4l2_request'
libva info: Trying to open /usr/local/lib/aarch64-linux-gnu/dri/v4l2_request_drv_video.so
libva info: Found init function __vaDriverInit_1_6
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.6 (libva 2.6.0)
vainfo: Driver version: v4l2-request
vainfo: Supported profile and entrypoints
     VAProfileMPEG2Simple            : VAEntrypointVLD
     VAProfileMPEG2Main              : VAEntrypointVLD
     VAProfileH264Main               : VAEntrypointVLD
     VAProfileH264High               : VAEntrypointVLD
     VAProfileH264ConstrainedBaseline: VAEntrypointVLD
     VAProfileH264MultiviewHigh      : VAEntrypointVLD
     VAProfileH264StereoHigh         : VAEntrypointVLD
vlc abbreviated output:
> opengl video, vaapi hwaccel
[0000ffff5cc19640] avcodec decoder: Using v4l2-request for hardware decoding
ffmpeg -decoders | grep v4l2request output:
Quote: V..... h263_v4l2request h263 (v4l2request) (codec h263)
V..... h264_v4l2request h264 (v4l2request) (codec h264)
V..... hevc_v4l2request hevc (v4l2request) (codec hevc)
V..... mpeg1_v4l2request mpeg1 (v4l2request) (codec mpeg1video)
V..... mpeg2_v4l2request mpeg2 (v4l2request) (codec mpeg2video)
V..... mpeg4_v4l2request mpeg4 (v4l2request) (codec mpeg4)
V..... vc1_v4l2request vc1 (v4l2request) (codec vc1)
V..... vp8_v4l2request vp8 (v4l2request) (codec vp8)
V..... vp9_v4l2request vp9 (v4l2request) (codec vp9)
screenshot eye candy
@xmixahlx  great work, I was looking for something like this to as I was going to test Kodi on my PBP with but with VPU support and using USB-C to DVI (HDMI) on Manjaro KDE. But seems there is no already package for these kinde of support on Manjaro KDE jet.
Do you have some sources for your PKGBUILDs or you are building packages without PKGBUILDs?
From arbian forum I have these information (from 2019), the kwiboo's rockchip-linux repos you already linked.
The VPU in rk3288 (vpu1) should have VP8 support, same as the VPU in rk3328/rk3399 (vpu2) rk3288 has a second VPU block that can decode hevc rk3328/rk3399 has a second VPU block (rkvdec) that can decode h264/hevc/vp9 (they have two different vpu blocks that can decode h264)
(02-19-2020, 12:38 AM)vrabac Wrote: @xmixahlx  great work, I was looking for something like this to as I was going to test Kodi on my PBP with but with VPU support and using USB-C to DVI (HDMI) on Manjaro KDE. But seems there is no already package for these kinde of support on Manjaro KDE jet.
i'm on debian sid arm64 and following guidance from kernel patches and commentary. keep an eye out for av's arch patches. we're collaborating on pine64 irc occasionally.
https://aur.archlinux.org/packages/?O=0&..._Search=Go
Fantastic! I haven't been able to replace my Thinkpad just yet because of a lack of video acceleration in Manjaro. Looks like it won't be too long until it'll be plug and play.
(02-19-2020, 08:20 AM)amiraeva Wrote: Fantastic! I haven't been able to replace my Thinkpad just yet because of a lack of video acceleration in Manjaro. Looks like it won't be too long until it'll be plug and play.
The last blog post had a panfrost installation script that got hardware acceleration working on my pine book pro.
panfrost hwaccel and hantro/rkvdec hwaccel are different.
hantro/rkvdec are the rockchip hwaccel kernel modules for video decoding (VPU).
there are numerous capabilities of the rockchip VPU that are not yet utilized, and development is ongoing.
one of the main developers, kwiboo, also is on the libreelec team and their distro is the most advanced in this regard. other distros will use this as a base until accepted upstream to provide similar support.
is the patched kernel  an must to or optional? I used under Manjaro Arm 20.02 the AndreVallestero PKGBUILDs but having problem to compile ffmpeg but i just compiled and installed these to prior to compile ffmpeg: libva-hantro-h264-git and libva-v4l2-request-hantro-h264-git
CC      libavcodec/v4l2_m2m.o In file included from /usr/include/string.h:494,                 from ./libavutil/common.h:40,                 from ./libavutil/avutil.h:296,                 from ./libavutil/samplefmt.h:24,                 from ./libavcodec/avcodec.h:31,                 from libavcodec/v4l2_m2m.c:30: In function ‘strncpy’,    inlined from ‘ff_v4l2_m2m_codec_init’ at libavcodec/v4l2_m2m.c:362:9: /usr/include/bits/string_fortified.h:106:10: warning: ‘__builtin___strncpy_chk’ specified bound depends on the length of the source argument [-Wstringop-overflow=]  106 |   return __builtin___strncpy_chk (__dest, __src, __len, __bos (__dest));      |          ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ libavcodec/v4l2_m2m.c: In function ‘ff_v4l2_m2m_codec_init’: libavcodec/v4l2_m2m.c:362:35: note: length computed here  362 |         strncpy(s->devname, node, strlen(node) + 1);      |                                   ^~~~~~~~~~~~ CC      libavcodec/v4l2_m2m_dec.o CC      libavcodec/v4l2_m2m_enc.o CC      libavcodec/v4l2_request.o libavcodec/v4l2_request.c: In function ‘v4l2_request_queue_decode’: libavcodec/v4l2_request.c:216:90: error: ‘V4L2_BUF_FLAG_M2M_HOLD_CAPTURE_BUF’ undeclared (first use in this function)  216 |     ret = v4l2_request_queue_buffer(ctx, req->request_fd, &req->output, last_slice ? 0 : V4L2_BUF_FLAG_M2M_HOLD_CAPTURE_BUF);      |        ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ libavcodec/v4l2_request.c:216:90: note: each undeclared identifier is reported only once for each function it appears in libavcodec/v4l2_request.c: In function ‘ff_v4l2_request_decode_slice’: libavcodec/v4l2_request.c:300:37: error: ‘V4L2_BUF_CAP_SUPPORTS_M2M_HOLD_CAPTURE_BUF’ undeclared (first use in this function)  300 |     if ((req->output.capabilities & V4L2_BUF_CAP_SUPPORTS_M2M_HOLD_CAPTURE_BUF) != V4L2_BUF_CAP_SUPPORTS_M2M_HOLD_CAPTURE_BUF)      |                                     ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ make: *** [ffbuild/common.mak:59: libavcodec/v4l2_request.o] Error 1 ==> ERROR: A failure occurred in build().    Aborting...
the patched kernel provides necessary kernel headers for ffmpeg-v4l2-request, although mpeg2video hwaccel is now working with mainline kernel. (i tested with 5.6.0-rc3+tsys). i recommend applying the libreelec kernel patches if you want to test.
things are picking up momentum. it looks like 5.7 will include many hwaccel improvements. see:
https://patchwork.kernel.org/patch/11403025/
a good read on firefox wayland:
https://mastransky.wordpress.com/2020/03...n-wayland/
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,344 03-15-2025, 01:47 AM
Last Post: frank_philip
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,425 09-07-2023, 09:38 PM
  kernel module that supports usb-c hdmi alexandre 16 29,865 05-14-2023, 09:58 PM
Last Post: rathofkhan3
  Manjaro update broke hardware video acceleration with mpv myself600 2 5,037 01-25-2023, 09:12 AM
Last Post: myself600
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,923 12-09-2022, 12:43 PM
Last Post: as365n4
  bootloader menu to pick a kernel - what is the current situation in in early 2022? maxtothemax 4 8,439 02-05-2022, 03:04 PM
Last Post: maxtothemax
  Kernel panics solostian 17 29,550 01-26-2022, 08:08 AM
Last Post: TRS-80
  Kernel 5.17 will improve VP9 support? jiyong 1 6,001 01-16-2022, 08:26 PM
Last Post: xmixahlx
  red/green power led not working with kernel 5.14 alchemist 4 9,231 11-04-2021, 04:09 AM
Last Post: alchemist
  Very slow glamor 2D acceleration hjalfi 3 9,492 09-06-2021, 12:54 PM
Last Post: jbrock
