openHab2 on pine64
(04-16-2016, 10:12 AM)tomekr Wrote: in /dev i get
crw-rw----  1 root dialout 188,   0 Apr 16 17:50 ttyUSB0
but i still get
COMMUNICATION_ERROR): Serial Error: Port /dev/ttyUSB0 does not exist
any ideas ?
The user running openHAB needs to be part of the group dialout in order to get access to /dev/ttyUSBX.
but i still get
any ideas ?
I   add user root do dialout group    and chmod a+rw /dev/ttyUSB0
Now it looks like
crw-rw-rw-  1 root dialout 188,   0 Apr 16 22:51 ttyUSB0
but nothing happened - still Serial Error: Port /dev/ttyUSB0 does not exist
How did you install openHAB? Are you running OpenHAB inside a chroot environment or Docker container?
(04-16-2016, 11:25 PM)umiddelb Wrote: How did you install openHAB? Are you running OpenHAB inside a chroot environment or Docker container?
No
I installed  Java™ SE Runtime Environment and openHab2 from cloudless https://openhab.ci.cloudbees.com/job/ope...tribution/
I didn't have problems with finding the serial port through openHAB on my first attempts, so I cannot really help here either.
What you should note nonetheless that even if the port is found, you there is still a blocking issue in supporting serial dongles.
If anybody can help getting nrjavaserial compiled for arm64, it would be gorgeous!
Regards,
Kai
(04-17-2016, 06:10 AM)kai Wrote: If anybody can help getting nrjavaserial compiled for arm64, it would be gorgeous!
Done ... libNRJavaSerial.so
Cheers
Uli
  openHABian for pine64 available dmcwhinnie 5 17,672 12-20-2017, 10:38 PM
Last Post: pineadmin
  Show Hubpanel on pine64 display Beta 0 4,936 04-15-2017, 05:44 AM
Last Post: Beta
Tongue Pine64 with Openhab2 - Starting guide/accessories g_t_j 4 14,918 03-12-2017, 05:13 PM
Last Post: BatoXan
  openHAB Packaging for the Pine64 kai 19 50,801 02-21-2017, 07:19 AM
Last Post: BatoXan
  Help with Openhab2 please Dayve 6 15,932 02-01-2017, 09:22 PM
  Pine64 and Aeon labsZ-Stick tomekr 1 7,436 12-19-2016, 05:41 PM
Last Post: Trond
  Pine64 and MQTT Grootkonijntje 2 11,933 09-22-2016, 04:01 AM
Last Post: pfeerick
  openHAB just up on Pine64 :-) tllim 2 11,268 05-04-2016, 05:27 AM
Last Post: Luke
