Chromium will not start
I am unable to run Chromium. Every time I try to start it it seems to go through the loading and then immediately shuts down. Any thoughts on what I am doing wrong? It worked on first boot but when I tried to do sync a couple of times it presented with the previous symptom. Is there a way to reload with the default config? I tried loading with synaptic but still the same problem. Thanks for any help.
I assume you're using the default Debian. Did you uninstall/reinstall Chromium? The OOTB Debian uses specific flags on the launcher for the browser, you may be missing those if you replaced it. If you do a search of the forums, you should be able to find the flags you need.
I am using the default Debian, what is OOTB Debian? I will search for flags, thanks.
That's the one. Default = Out Of The Box. Add those flags to your launcher command.
Hi tried "out of the box" and tried loading new armhf from snap store but can't seem too get chromium running. get core18 not present. Is there any clean, from ground zero, way too install the correct initial version to my pinebook pro?
(03-05-2020, 04:59 AM)sititahwsi@gmail.com Wrote: Hi tried "out of the box" and tried loading new armhf from snap store but can't seem too get chromium running. get core18 not present. Is there any clean, from ground zero, way too install the correct initial version to my pinebook pro?
Looks like you are not the only one: https://bugs.launchpad.net/ubuntu/+sourc...ug/1808959
As suggested in the post: sudo snap refresh chromium --channel=stable/core16
  Black screen by start up bluedemon382 10 11,929 07-27-2023, 07:49 AM
Last Post: dstallmo
  I have two different versions of Chromium on my Pro! Nobot 2 5,633 06-01-2021, 02:34 PM
Last Post: Nobot
  Chromium Dino game is slow/glitchy stozi 0 3,220 04-21-2021, 08:18 AM
Last Post: stozi
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 30,743 03-12-2021, 10:46 AM
Last Post: spikerguy
  Issues with chromium-docker PVD 4 10,978 12-17-2020, 10:11 PM
Last Post: warehouses
  How to flash the emmc when it has Chromium on it? U47 3 7,846 07-10-2020, 10:07 AM
Last Post: U47
  Chromium browser on PBP can't upload files on websites Wawe 0 3,464 07-03-2020, 11:06 AM
Last Post: Wawe
  Initial Start lyssa 2 5,635 06-21-2020, 02:54 PM
Last Post: lyssa
  How do you upgrade Chromium on default Debian that came with my PBP james64 6 13,797 05-26-2020, 07:21 AM
Last Post: User 6582
  Chromium on Pinebook Pro blocked by Google: "This browser or app may not be secure" lowry 4 10,865 03-05-2020, 07:01 AM
Last Post: Eight Bit
