opensuse and fedora images
Hey everyone, I've created working images for openSUSE Tumbleweed and Fedora. You can grab them here https://github.com/smithmcgriff
Awesome! Feel free to add these to the Software Release wiki page! (You can use your forum login to make edits to a page.)
(02-03-2020, 11:25 AM)tophneal Wrote: Awesome! Feel free to add these to the Software Release wiki page! (You can use your forum login to make edits to a page.)
I was able to add it to the software page, but I'm unsure of how to add a .png photo, and link it to the main wiki page for pinebook pro. I've never edited a wiki before. Any help would be much appreciated. Thanks!
For the time being, you can upload the image you want to use to something like imgur and use a direct link to the image to add it to the wiki. I know there's away to add images, but it's limited to keep the use of images, where unneeded, down.
(02-03-2020, 10:02 AM)smithmcgriff Wrote: Hey everyone, I've created working images for openSUSE Tumbleweed and Fedora. You can grab them here https://github.com/smithmcgriff
Thanks for your work, I've successfully tried the Fedora image, but it seems like big cluster is disabled, so only small cores are available, is this something set during the build of an image?
That is covered in the readme file I believe. You can remove "maxcpus=4" from "/etc/extlinux/extlinux.conf". That should add full power back.
bil
I installed the Fedora Version to an SD card. I followed your directions which are thorough and well done, thank you
It runs alright. It is very slow to boot. Some applications run quite well, others like software center just appear to stall out.
Thank you for your work.
bill
  Fedora 37 installation gswatkins 16 19,004 03-16-2024, 03:09 PM
Last Post: michel_luc
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,256 10-28-2023, 09:53 AM
Last Post: tydeman
  Upgrade Fedora from 37 to 38? acruhl 2 3,659 07-12-2023, 09:31 PM
Last Post: acruhl
  newer ""emmc-installer" images (manjaro xfce) magistral 1 3,315 10-10-2022, 06:22 AM
Last Post: maxjrh
  Fedora Workstation (36) on Pinebook Pro u974615 13 19,001 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 4,307 08-22-2022, 12:12 PM
Last Post: snorwood
  OpenSUSE with XFCE/ GNOME3 now available Luke 35 96,942 01-10-2022, 01:06 PM
Last Post: werwolf
  Fedora 33 to 34 upgrade issues tydeman 2 6,359 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 4,040 11-30-2021, 10:47 AM
Last Post: pine76
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 5,596 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
