Armbian for the Pinebook Pro [WIP]
WIP Armbian OS images for the Pinebook Pro are now available.
Download Page
very pleased with the pace of things with the pbp, i haven't seen anything like it before outside raspberry pi stuff. i'm spending a lot of time lurking here just to see things develop in front on my eyes.
Looks good for now. Konsole does not crash on dmesg, Stella runs fine on software rendering, Kubuntu PPA works fine. Tomorrow I can try KDE Neon and upgrade to 19.10. For now, it looks very stable and usable. OpenGL renderer is just llvmpipe, but the performance is nice.
edit: sound does not seem to work
edit2: neither I do not see the battery percentage
edit3: sleep is not supported (or disabled)
(01-19-2020, 04:05 PM)Wizzard Wrote: Looks good for now. Konsole does not crash on dmesg, Stella runs fine on software rendering, Kubuntu PPA works fine. Tomorrow I can try KDE Neon and upgrade to 19.10. For now, it looks very stable and usable. OpenGL renderer is just llvmpipe, but the performance is nice.
You checked the Bionic image, right? On Buster I had a problem with wifi, but the whole overall also looked good (also without sound, battery and sleep).
Yes, Bionic, I installed all of the KDE packages I use on regular Ubuntu install. Will play with that tonight to check the sound issue.
Ok, so this is what I found;
- there is no problem upgrading to 19.10 also with Kubuntu PPA enabled
- sound works after some playing. I installed all Phonon packages and played with Audio settings in KDE and it finally works.
- Stella finally runs at full speed also in OpenGL and OpenGL ES mode
- Konsole does not crash on dmesg command
- I can install Krita (there is arm64 package available)
- Sleep mode is supported (but waking up does not work, there are some error messages in console after and I have to reboot)
- battery status is not shown yet
This looks to be an ideal OS for me so far.
Also, I am trying to solve this issue:
sudo apt update                Hit:1 http://ppa.launchpad.net/kubuntu-ppa/backports/ubuntu eoan InRelease Hit:2 http://ports.ubuntu.com/ubuntu-ports eoan InRelease Hit:4 http://ports.ubuntu.com/ubuntu-ports eoan-security InRelease                      Hit:5 http://ppa.launchpad.net/libretro/stable/ubuntu eoan InRelease                Hit:6 http://ports.ubuntu.com/ubuntu-ports eoan-updates InRelease Hit:7 http://ports.ubuntu.com/ubuntu-ports eoan-backports InRelease                     Hit:8 http://ports.ubuntu.com/ubuntu-ports eoan-proposed InRelease                      Hit:3 https://apt.armbian.com eoan InRelease                                            Traceback (most recent call last):                                       File "/usr/lib/cnf-update-db", line 26, in <module>     col.create(db)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create     self._fill_commands(con)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands     self._parse_single_commands_file(con, fp)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 165, in _parse_single_commands_file     suite=tagf.section["suite"] KeyError: 'suite' Error in sys.excepthook: Traceback (most recent call last):   File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 145, in apport_excepthook     os.O_WRONLY | os.O_CREAT | os.O_EXCL, 0o640), 'wb') as f: FileNotFoundError: [Errno 2] No such file or directory: '/var/crash/_usr_lib_cnf-update-db.0.crash' Original exception was: Traceback (most recent call last):   File "/usr/lib/cnf-update-db", line 26, in <module>     col.create(db)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create     self._fill_commands(con)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands     self._parse_single_commands_file(con, fp)   File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 165, in _parse_single_commands_file     suite=tagf.section["suite"] KeyError: 'suite' Reading package lists... Done E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi' E: Sub-process returned an error code
.png   Screenshot_20200120_203754.png (Size: 58.59 KB / Downloads: 861)
.png   Screenshot_20200120_204036.png (Size: 76.28 KB / Downloads: 1,006)
Armbian, Running debian, not ubuntu. Anyone have any luck getting wifi to connect? it's on, and sees networks, but fails on connection, as if the password was wrong. (It's not, tried three different networks I control, and failed connecting to any of them)
I'd love to have 'pure' debian stable (sort of) running on my pinebook pro, instead of oldstable.
Yesterday I made another test with Armbian Ubuntu, installed KDE Neon on Bionic and it also runs well, including acceleration and sound. Sleep does work too, but does not wake up. Battery status does not work.
I found out that the following previous error is caused by changing bionic to eoan of focal in sources list. When I change that, this error appears after running apt update.
Traceback (most recent call last):                                      File "/usr/lib/cnf-update-db", line 26, in <module>    col.create(db)  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create    self._fill_commands(con)  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands    self._parse_single_commands_file(con, fp)  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 165, in _parse_single_commands_file    suite=tagf.section["suite"] ...
Seems that KDE Neon does not have kernel module working.
.png   Screenshot_20200121_184801.png (Size: 57.73 KB / Downloads: 886)
Nobody using Armbian Ubuntu?
Today I upgraded to 20.04 and it runs fine, accelereation and sound works, battery not. Stella runs fast! Smile
  Boot Order in Pinebook Pro food 14 20,072 11-16-2026, 01:09 AM
Last Post: NorrisFByrd
  Window Maker Live for Pinebook Pro vajak 9 6,775 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,423 08-09-2025, 06:53 AM
Last Post: Sb2024
  Armbian fix, current version now works Sb2024 0 3,117 08-08-2025, 08:49 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,906 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,941 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,727 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 18,093 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,549 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,829 12-11-2023, 03:47 AM
Last Post: calinb
