MATE Terminal copy and paste
Hi all,
I just opened my account on this forum and this is my first post, so I hope I am writing in the right section, and that this thread hasn't been treated before already. Anyway I haven't found it!
Usually I copy and paste between Terminal and other windows with the regular CTRL+SHIFT+C / CTRL+SHIFT+V but that doesn't work on the default MATE Terminal on my PBP.
I've checked the Keyboard Shortcuts within the Terminal menu, and it indeed has the shortcuts I am used to.
I've seen an issue raised on the MATE Terminal repo: https://github.com/mate-desktop/mate-ter...issues/239
But it is closed now and the fix doesn't seem to work with me.
So my question is, is this a known issue with the PBP or with MATE Terminal itself (I used xfce and Gnome before)? Does anyone have a work around?
Copy and Paste works within the Terminal itself, but not from another program, so I thought it should be something with different clipboard access...
Anyway, got my PBP yesterday, am even more happy with it than I expected. I'm happy to become part of the community!
I think you need to install xclip using synaptic package manager or apt
sudo apt install xclip -y
Linux n00b trying to learn.
Brute force and ignorance sometimes works!
| Pinebook Pro + Toshiba OCZ RC100 240GB |
(01-07-2020, 11:39 AM)gandlers Wrote: I think you need to install xclip using synaptic package manager or apt
Yes, thought of that, hasn't changed anything. For now my solution is to just use the xfce4 terminal, which I don't mind.
I was having the same issues with copy/paste not working, installing xclip fixed it for me.
The only other thing i can think of is I had fixed the keymaps as well, not sure of that was before of after fixing the copy/paste issue.
Link to the tutorial on fixing the keymaps https://forum.pine64.org/showthread.php?tid=8584
Probably totally unrelated, but that's all I can think that maybe different.
  suddenly the terminal won't accept me as root hayduke 1 3,301 09-21-2022, 07:37 PM
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 29,702 08-18-2022, 11:26 PM
Last Post: calinb
  After update in Ubuntu bionic mate system crashed Wawe 2 7,354 04-18-2021, 04:52 AM
Last Post: Wawe
  Ubuntu MATE 18.04 Can't boot after update hankg 2 8,738 12-15-2020, 01:53 AM
Last Post: BryanF
  ayufan Ubuntu Mate 0.9.14 black screen boot on new Pinebook Pro EricL 3 8,848 06-22-2020, 09:45 PM
Last Post: trinapicot
  Better (than default Debian/MATE) Linux distro? mspohr 34 62,102 06-11-2020, 01:34 PM
Last Post: s3rvant
  Ubuntu mate boot failure hdk 3 8,298 05-14-2020, 06:11 AM
Last Post: ndp
  0.9.14 Release: Ubuntu 18.04 with Mate & LXDE Desktop Luke 86 173,192 04-09-2020, 09:33 AM
Last Post: mmt
  Compiling WireGuard (and other things requiring linux-headers) on Debian+Mate Dendrocalamus64 1 6,888 04-02-2020, 07:07 PM
Last Post: Dendrocalamus64
  Debian MATE update v1.6 fire219 8 17,495 03-31-2020, 01:01 AM
Last Post: hdk
