Baldur's Gate on Pinebook Pro
Hi, I've managed to get Baldur's Gate II running on Pinebook Pro with Manjaro. In order to achieve that you need to use the GemRB open-source engine. I've published a script which achieves that. Before running, you need to download the latest release from https://github.com/gemrb/gemrb/releases/tag/v0.8.6. Baldur's Gate is bundled with it's enhanced edition on GOG. You can extract it using innoextract, available in Manjaro repositories. I had issues with the git version, though it might have had to do with bad cmake flags. Please note that the script doesn't install the dependencies - check out the sources.
https://bitbucket.org/brzegorz/pinebookp...l_gemrb.sh
Sources:
http://gemrb.org/wiki/doku.php?id=installation
Things I had to correct in order to get it to work:
- Your installation should be in a folder without spaces, e.g. "BaldursGateII" instead of "Baldurs Gate II"
- cmake .. -DDISABLE_WERROR=1 -DSDL_BACKEND=SDL2 -DOPENGL_BACKEND=OPENGL -DSTATIC_LINK=enabled
    - I haven't checked if DISABLE_WERROR and SDL_BACKEND make a difference
   - OPENGL_BACKEND=GLES caused segfaults when starting the game for me
    - STATIC_LINK=enabled is needed for the game to compile. It might have to do with my Python installation, but, well, it works
- My gemrb.cfg: https://pastebin.com/LvcwRhzw. The annoying thing is that the one which is copied from build dir has wrong paths
- to run: gemrb -c gemrb.cfg
I'm working on the widescreen mod and testing how it actually works right now.
EDIT1: I've freed my friends and won an epic battle with Mephits on 640x480. Stuff seems to be working just fine.
EDIT2: I've added a script to install the widescreen mod. Mephits die twice, everything works: )
https://bitbucket.org/brzegorz/pinebookp...escreen.sh
  Boot Order in Pinebook Pro food 12 17,844 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,929 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,978 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,299 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,566 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,141 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 17,089 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,084 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,246 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 160,751 12-08-2023, 11:25 PM
