Reaper on Pinebook Pro
As promised to @Jeremiah Cornelius in the Initial Impressions thread, I am posting some of my initial findings with Reaper on the PBP. My setup is as follows:
OS: Debian/MATE default image (Kernel 4.4.207 - Latest MrFixit updates)
Reaper: v6.02 (armv71)
Audio Interface: Behringer U-Phoria UMC202HD
Microphone:  RØDE NT1-A
Installing and running Reaper was fairly straightforward. Just follow the instructions on the Reaper website.
After starting up Reaper I was only getting input from the built in Microphone. I had to switch PulseAudio to use the Behringer interface.
Once that was resolved. Everything recorded correctly.
I did notice that on the right side USB port everything worked fine. The left side USB port introduced lots of latency and was unusable. I have not tested my USB-C hub because I do not want to introduce more latency. Although this might be an interesting testing at a later stage.
I won't subject you to my test recording. It was done in my echo-y office and my voice is not exactly great. Big Grin
But, I have included a screenshot of the setup.
.png   ReaperDAW.png (Size: 287.12 KB / Downloads: 829)
I will also try to grab some CPU performance screenshots but I have not got around to doing that yet.
I should also mention that the use case I have (or rather my wife) is that of Audiobook narration. So it is a single mono track recording with very few filter and effects to reduce some room noise. It is not the most taxing workload but it is good to see that the PBP can cope quite nicely. Doing multiple tracks with lots of effects may not work quite so well.
(01-03-2020, 12:51 PM)Twix166 Wrote: As promised to @Jeremiah Cornelius in the Initial Impressions thread, I am posting some of my initial findings with Reaper on the PBP. My setup is as follows:
< SNIP >
Thanks very much for this helpful response! The PulseAudio and USB pointers are really helpful. I will be doing multitracking, with lots of general MIDI and effects. There are good reports of Traction Waveform 10 on RPi 3+/4, so I'm in a hopeful mode.
Does anyone know if unmodified RPi binaries for Raspbian will run on PBP?
— Jeremiah Cornelius
So, these are some (very unscientific) screenshots of CPU usage during system idle, Reaper Playback and Reaper recording. During reaper recording the CPU never went above 1.51GHz. So there is still a bit of headroom. Most of the time the CPU was hovering around the 1.20GHz. I was recording on one track with one microphone.
Idle
.png   System - Idle CPU usage.png (Size: 91.06 KB / Downloads: 730)
Playback
.png   Reaper - Playback CPU usage.png (Size: 103.34 KB / Downloads: 820)
Recording
.png   Reaper - Recording CPU usage.png (Size: 96.66 KB / Downloads: 743)
(01-03-2020, 03:21 PM)Twix166 Wrote: So, these are some (very unscientific) screenshots of CPU usage during system idle, Reaper Playback and Reaper recording. During reaper recording the CPU never went above 1.51GHz. So there is still a bit of headroom. Most of the time the CPU was hovering around the 1.20GHz. I was recording on one track with one microphone.
Idle
Playback
Recording
Looks very good. Aside from the fact that I use the same GTK+ theme on my own Gnome setups. :-)
Is the low latency kernel compatible or even advantageous with the PBP?
(01-03-2020, 12:51 PM)Twix166 Wrote: I did notice that on the right side USB port everything worked fine. The left side USB port introduced lots of latency and was unusable.
The one on the right side is USB 3.0, on the left is USB 2.0
Thank you for sharing, great post.
I think that's the other way around;
Left side - USB C/3.0 & USB A/3.0
Right side - USB A/2.0
If looking at the Pinebook Pro open bottom picture, it's flipped left / right.
I do wonder why @Twix166 would have problem with a USB 3.0 port. My only thought is that USB power save could be kicking in. I have the same issue on my newish miniature desktop. Have not solved it completely, yet.
Arwen Evenstar
Princess of Rivendale
(01-09-2020, 06:03 AM)Arwen Wrote: I think that's the other way around;
It is  Blush
I had it closed and facing the other way.
I was also thinking the latency was because 2.0 wasn't fast enough.
I use Focusrite gear and their website explains that they are still using USB 2.0 because it's fast enough and USB 3 for audio doesn't have much, if any, advantages.
  Updated Pinebook Pro? tantamount 2 2,613 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 8,380 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,955 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 3,629 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 7,082 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 11,015 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 2,150 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 9,033 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 5,385 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 30,405 03-09-2025, 11:17 AM
Last Post: davisthomas
