RockPro64 as Synology NAS alternative!?
Hello all here,
I am new with Pine64, had a chat lately with a friend regarding NAS and it's power consumption.
I am thinking about switching from my Synology 713+ NAS to a Pine64 RockPro64-4GB NAS.
My 713+ Synology uses about 40Watt's constant incl. 2 WD RED 3TB HDD's (in RAID).
Seems that the Synolofy HDD's don't fall asleep after some time
Can you guys tell me about your the RockPro64 power consumption as a NAS with 2 HDD's ?
Started reading here:
https://wiki.pine64.org/index.php/NASCase
Some more questions:
You can connect only one fan on the PCB, in the NAS-case or on the CPU, what do you advise? Or can it run only with the largest heatsink?
As OS OpenMediaVault is suggested, this is best to use or do you have an alternative?
On the Synology (which I only use as Storage and hosting photo's) I use the programm "Photostation", what do you guys prefer to use?
Between my two Synology's I use "Hyper Backup" to sync from one to another.
I believe "Hyper Backup" is a Rsync tool?
Is it possible to Sync from OpenMediaVault to `Synology #2 ?
Thx!
Gr. Hemertje
  • 8,4 - 9,3 Watt mit 2 Stück 2,5 Zoll HDD (hdparm inactive)
  • 5,6 Watt mit 2 Stück 2,5 Zoll HDD (hdparm aktive)
With two 3,5 Zoll HDDs 25 - 30W
2. You don't need an fan, when you only use your NAS as data storage.
3. I am using only debian for my NAS and NFS for LAN. Backups i do with rsync.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(12-21-2019, 12:40 PM)Bullet64 Wrote: Hello,
1.
Hello Bullet64,
Thx for your reply, Danke fur ihnen antword
Grussen aus Holland...
Frank, what do you use as "photostation" ?
WD RED 3TB 3,5"
HDDhttps://storagereview.com/western_digital_red_nas_hard_drive_review_wd30efrx
Specs: Power 2TB/3TB: read/write 4.4W, idle 4.1W, standby/sleep .6W
Do your HDD's in combination with the Pine64 NAS get to sleep when not used?
@hemertje
I use nextcloud for my photos. Nextcloud don't run on my NAS, nextcloud runs on an hosted server. I only save backups on my NAS.
3. RockPro64 v2.1
  RockPro64 automatically run after power recovery - my solution g2t 1 1,788 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 4,470 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,801 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,538 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,750 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,266 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,930 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 13,993 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 5,220 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 6,614 04-06-2023, 02:46 PM
