Citrix ICA Client on Pinebook Pro
For google, following generations and me in a few months:
The Citrix ICA Client won't install on an armhf system with an aarch64 kernel.
Use "dpkg -i icaclient_19.10.0.15_armhf.deb" - installation fails. The do "sudo nano /var/lib/dpkg/info/icaclient.postinst". Go to line 2213, replace
echo $Arch|grep -i "^arm" >/dev/null
with
echo $Arch|grep -i "^a" >/dev/null
and do "apt -f install" - the icaclient will now configure correctly.
Unfortunately, I haven't yet found the Citrix HDX Media engine for armhf (not distributed freely by Citrix) - it should exist; I use an armhf thin client with HDX at work.
This worked like a charm, thank you!
I would also add something that I ran into related to getting Citrix running on other Linux machines I've connected on (this may or may not be necessary for everyone). When trying to connect to my thin/thick desktop, I will receive an error about "0.0.0.2 - Thick Desktop location not found". The issue in the past (and solved it this time as well) was that the certificates were not found. By creating a symlink from the system's SSL cert location to the Citrix location, Citrix now has all the same certs the system has:
sudo rm -r /opt/Citrix/ICAClient/keystore/cacerts
sudo ln -s /etc/ssl/certs /opt/Citrix/ICAClient/keystore/cacerts
My understanding of all the ins & outs here is limited, so feel free to correct/clarify anything, but I hope this helps anyone else running into the same issues I have in the past!
  Boot Order in Pinebook Pro food 12 16,761 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,372 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,737 08-09-2025, 06:53 AM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,949 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,400 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 11,684 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 16,408 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,751 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,889 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 157,495 12-08-2023, 11:25 PM
