Cannot power on the PBP
I just received my new Pinebook Pro today.
But I can not turn it on Sad
When I press the Power-Button most times nothings happens, sometimes the power-LED turns on for a quarter second and then it's off again.
I've tried with and without power-supply, read in the wiki about the emmc-switch and the SD-Card ribbon.
Tried both with no luck.
I tried also without battery and the power-brick cable connected, but also nothing.
Any suggestions?
Perhaps if the processor was a mc68060...
(11-09-2019, 11:35 PM)Kochise Wrote: Perhaps if the processor was a mc68060...
With a 68060 it would be no problem *g
But I also got the RockChip to boot.
The eMMC seems to be empty, I deselected it with the switch and used a SD-Card to boot.
And I learned that you have to push the power-button longer to turn it on.
There should be something like a FAQ for beginner.
If you booted from sdcard, try and write the default image to the emmc with dd. Just to check the emmc is good.
Checked the emmc with gparted, it was complete empty.
Just wrote the Image to the emmc.
Now it's booting from it Smile
@MC68060, just added that issue to the troubleshooting guide;
Wiki - Pinebook Pro - New from the factory - Pinebook Pro won't boot / power on
Arwen Evenstar
Princess of Rivendale
(11-10-2019, 03:29 PM)Arwen Wrote: @MC68060, just added that issue to the troubleshooting guide;
Good stuff, doing a great job.
  Pinebook64 Pro doesn't power on andrea_from_italy 9 7,543 03-20-2025, 10:07 AM
  Lockable-until-power-cycle persistent storage Melab 0 2,336 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 2,627 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 2,291 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 4,758 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 6,384 09-09-2022, 08:13 PM
  Replacement Power Cord recommendation? nathanielwheeler 3 6,315 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 3,983 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 11,147 11-30-2020, 10:57 PM
Last Post: rimaille
  Power consumption and suspend to ram robt 33 69,538 11-30-2020, 04:32 PM
