A true mainline Linux Kernel for the Pinebook Pro
(11-08-2019, 04:39 AM)danielt Wrote: I'll go looking for more clues later today but I just wondered if you have seen anything like this yourself as you've been working.
Yeah, interestingly I had one similar event last evening. Upon starting the X user session from lightdm the eDP link failed and was unable to sync again. Also there seems to be a correlation between enabling i2s0 and i2s2 and failure of the eDP link. Thus I disabled i2s0 and i2s2 in my devicetree. It is happening too seldomly to me to pin it to anything yet though.
EDIT: I've pushed an additional commit to my gitlab branch that slows the display clock a tat. While I don't think it will make any difference you are welcome to test it out.
Thanks. I'll do some testing and let you know.
Two new feature in the mainline kernel as of now:
  • USB-C charging is working (wow, the dt-binding docs of the fusb302 are really shitty)
  • Bootup time reduced from more than 3 minutes to less than 30 seconds through new defconfig
Manjaro ARM
Kernel dev
Buy me a coffee
(11-08-2019, 10:05 AM)tsys Wrote: Two new feature in the mainline kernel as of now:
Reduced boot time will be very welcome. I'll grab that in a second..
I didn't see any benefit from the changed display timings, nor from disabling i2s0 and i2s2. However I chased the error message into the code and came up with a simple DT change to get the driver to tolerate a missing HPD signal. I will need to turn on the debug messages to be absolutely sure I'm still reproducing the original problem but in the mean time if anyone else is having this kind of trouble then the following may help:
diff --git a/arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts b/arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts
index 569c1490b024..4df56b48bac4 100644
--- a/arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts
+++ b/arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts
@@ -380,6 +380,7 @@
       status = "okay";
       pinctrl-names = "default";
       pinctrl-0 = <&edp_hpd>;
+       force-hpd;
       ports {
               edp_out: port@1 {
(11-08-2019, 01:32 PM)danieltHowever I chased the error message into the code and came up with a simple DT change to get the driver to tolerate a missing HPD signal. I will need to turn on the debug messages to be absolutely sure I\m still reproducing the original problem but in the mean time if anyone else is having this kind of trouble then the following may help: Wrote:
@@ -380,6 +380,7 @@
       status = "okay";
+       force-hpd;
       ports {
               edp_out: port@1 {
Nice find! This might indeed be a problem. HPD of the panel is not connected, so this should probably have been in the devicetree all along. Thanks
Manjaro ARM
Kernel dev
Buy me a coffee
I noticed that the maximum clock is 1.8GHz in the Manjaro build, but the Ubuntu and Debian ones are able to go to 2.02GHz. Can this build be clocked to 2.02GHz as well?
(11-09-2019, 04:59 AM)brent.thierens Wrote: I noticed that the maximum clock is 1.8GHz in the Manjaro build, but the Ubuntu and Debian ones are able to go to 2.02GHz. Can this build be clocked to 2.02GHz as well?
Sure. I've added a 2 GHz operating power point @1.3V. One of the next manjaro builds will probably include this change.
Manjaro ARM
Kernel dev
Buy me a coffee
Major News:
Audio is now working \o/
Was just a simple matter of setting up the iomux correctly
Manjaro ARM
Kernel dev
Buy me a coffee
#19
(11-09-2019, 09:23 AM)tsys Wrote: Major News:
Awesome!
Preview 2 later today? Wink
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
#20
Just installed the M.2 adapter (after some mechanical optimization) and PCIe works with PCIe 2.0 speed and full 4 lanes.
Manjaro ARM
Kernel dev
Buy me a coffee
  Boot Order in Pinebook Pro food 12 17,931 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 5,986 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,002 08-09-2025, 06:53 AM
Last Post: Sb2024
  Can’t login to Linux fnosai 0 3,215 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,278 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 6,680 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,323 08-21-2024, 04:17 AM
  Slackware Linux working on PBP vxzero 0 3,942 06-05-2024, 04:30 PM
Last Post: vxzero
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,588 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,175 03-31-2024, 10:11 AM
Last Post: u974615
