How to install Ubuntu to eMMC and to install KDE (Neon)
#21
(11-04-2019, 06:29 PM)cristobalhdez Wrote:
(11-04-2019, 05:06 PM)i4g0 Wrote: Hello! I tried to follow this tutorial, but after step 4, I rebooted and now the PBP is stuck in a reboot loop, and never boots. This applied for with and without the microSD card in the PBP. I ran pretty much the exact dd command, with the img from MrFixit2001's github (Debian Desktop Community Build Image [microSD to eMMC] by mrfixit2001 from https://wiki.pine64.org/index.php/Pinebo...an_Desktop)
Has anyone else experienced this? Note: The OpenSesame screen never shows, just power on -> green light -> no green light -> power off, then repeats until I turn off the power. From my few hours experiencing the PBP I love it, and I'd like it back Smile
Can you try to write the image again with the next command?
sudo dd if=nameOfTheImageFile.img of=/dev/mmcblk1 status=progress
Unfortunately not, because the PBP doesn't boot ): , I think I messed up uboot. The PBP doesn't even boot from SD. Perhaps it is trying eMMC first and failing with no fallback?
#22
Hi Wizzard, thanks for your how-to.
I'm stuck on the second step: after I finish dd LXDE image to my microsd card I insert it to PBP, boot and.... standard preinstalled Debian boots instead of written Ubuntu image. Microsd is mounted in the Debian system, but not starting on the power on.
I'm completely new to arm devices, and cannot figure out what I'm doing wrong.
#23
(11-05-2019, 02:34 AM)Skywheel Wrote: Hi Wizzard, thanks for your how-to.
Hi, have you run the Debian update script in stock image? That icon in system tray, it should update uboot to allow booting from sdcard.
I am very sorry about that, but... why exactly you burned Debian image instead of Ubuntu? That OS was already installed on emmc, so this guide was meant to install Ubuntu image...
#24
The only reason I have is paranoia Tongue I just wanted to be sure the image was clean.
#25
Yes, I ran the script. Today will try Mate instead of LXDE. There is almost no chance that it will change anything, but at least I try...
#26
Heya Wizzard,
Thanks for the build and the how-to. I've been using this build for a couple of days and and it's running pretty well. I did have some issues with no audio from the browser after I initially installed it yesterday. Then I cloned mrfixit2001's github repo and ran the 1.4v of his update script and sound is now working again in the browser (firefox) .
One suggestion I would make is to remove the sound from the menu. It's pretty annoying when you're hovering over menu items and you get that "dink" sound every time. I realize this isn't your ubuntu build, but I wasn't sure where to post it.
[/url]
[url=https://imgur.com/a/5DQ7HBV]https://imgur.com/a/5DQ7HBV
#27
I'm in the same place I think. I flashed the debian image and now I can't boot from the emmc. Even worse i can't boot from the sdcard unless I have switched the emmc off internally.
Current symptoms:
- With the emmc switch on I'm stuck in a boot loop with the lcd backlight and the green power LED intermittently coming on. The green power led shows a moment of read activity before shutting off and restarting.
- With the emmc switch off i can boot off an sdcard with the mate image. Unfortunately I can't access the emmc card to reflash it.
- I've tried booting the debian image from an Sd Card and doesn't even appear to power on. No power LED, No backlight. I tried the most recent 2 versions, and the same result.
I'm not sure what to do next. I could try an OTG flash of the pro but the documentation is very not done.
#28
(11-06-2019, 09:26 PM)chzbacon Wrote: One suggestion I would make is to remove the sound from the menu. It's pretty annoying when you're hovering over menu items and you get that "dink" sound every time. I realize this isn't your ubuntu build, but I wasn't sure where to post it.
[/url]
As for me, because I use KDE, I do not have any sounds, and I even liked those Mate sounds, but thanks for the tip anyway, it may help someone.
(11-06-2019, 10:43 PM)electriccrowbar Wrote: I'm in the same place I think. I flashed the debian image and now I can't boot from the emmc. Even worse i can't boot from the sdcard unless I have switched the emmc off internally.
Seems there is some problem when we try to flash Debian on Debian and I do not understand why. Maybe @Mrfixit2001 could help?
#29
Current symptoms:
Sorry, if this is getting off-topic.  Can you boot SD with the eMMC switched off, switch the eMMC back on, then flash the eMMC?
You might want to take a look at these threads:
https://forum.pine64.org/showthread.php?tid=8162
https://forum.pine64.org/showthread.php?tid=8163
https://forum.pine64.org/showthread.php?tid=8031
#30
(11-07-2019, 07:37 AM)zaius Wrote: Sorry, if this is getting off-topic.  Can you boot SD with the eMMC switched off, switch the eMMC back on, then flash the eMMC?
I would want someone familiar with the hardware to tell me that's safe first.
(11-07-2019, 07:37 AM)zaius Wrote: You might want to take a look at these threads:
This thread specifically sounds like exactly what i'm going through. Having a serial cable sounds useful for debugging this. I may have to make one this weekend, but for now i'm pretty stuck.
  Install Tow-Boot on the SPI Shad0w 14 47,082 11-18-2024, 11:23 AM
Last Post: reukiodo
  How to rewrite uboot to emmc pineitup 5 15,664 12-27-2020, 10:35 AM
Last Post: nightranger73
  Video : How to install Armbian Reforged and set it up on PineBookPro / Gaming image NicoD-SBC 0 6,475 11-23-2020, 12:09 PM
Last Post: NicoD-SBC
  Citrix Receiver / ICAClient install for armhf Arwen 7 23,906 09-14-2020, 11:02 PM
Last Post: vb_linux
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 88,661 07-28-2020, 03:18 PM
Last Post: SamWilts
  Using 2 OS images on eMMC for safe upgrades Arwen 0 3,989 06-13-2020, 01:13 PM
Last Post: Arwen
  How to boot Manjaro from NVME with uboot on eMMC as400 47 100,336 06-07-2020, 02:37 AM
Last Post: as400
  Restoring the OS using the eMMC Adapter xircledev 3 12,302 02-20-2020, 05:16 PM
Last Post: Thovthe
  Quick Guide to installing Ubuntu Unity on your Pinebook Pro andybleaden@gmail.com 19 41,168 02-03-2020, 11:17 AM
Last Post: MIchael
