Heat issues
Hi
I have heard that the ROCK64 can run rather hot. I will use mine mainly for streaming. Will a heat sink be enough, or should I get a fan too?
The Rock64 really shouldn't need a fan under any conditions. A small heatsink is all you need to worry about, and it's still not even completely necessary.
Thank you very much
In my experience, rock64 1gb / usb3 / ext4 root file system, armbian , no heat sink / fan, compile aria2, make will work, make -j 2 will work, make -j3 and up will generate a lot of errors in dmesg / console and failed to compile. I then rebooted and it never went up... I need to physically access the hardware , fsck the file system and disconnect / reconnect the power supply to make rock64 great again.
From what temperature should I worry? when i use it for video vigilance 65º is the rule
I don't use a heat sink or case and I have the Rock64 running 24/7 as a home automation server under Armbian. I think some of the more exotic distros particularly those who have a heavy video overhead I imagine may need some form of passive cooling particularly those boards that are housed in low profile cases.
The Rock64 is a tinkerers board so you can expect to spend time and effort tailoring your setup to suit your own purposes. Armbian will work out of the box with little or no effort for those looking for a "plug'n'go" solution.
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,766 09-25-2026, 11:19 PM
Last Post: mysy
Question Constant RockPro64 PCIe SATA Issues Kwarter 0 5,113 01-22-2022, 05:16 PM
Last Post: Kwarter
Question Hardware issues with Rock64 grobbs 10 18,939 04-08-2021, 05:24 AM
Last Post: t4_4t
  Rock64 v2 network issues alephnull 2 7,785 05-29-2020, 06:00 AM
Last Post: maccarry
  Performance and stability issues Openmediavault jgpacc 10 23,915 11-02-2018, 01:46 PM
Last Post: jgpacc
  Odd HDMI issues jman005 0 3,185 10-26-2018, 09:15 PM
Last Post: jman005
