Is a KDE Neon version in the works?
The initial announcement had some vague stuff about working with KDE. Is a custom KDE Neon version (like for the original Pinebook) in the works?
Also very interested in this!
Yes, they just have to get their units.
Any update here? Smile
You can install a base ubuntu install (I used Ayufan's ubuntu LXDE install) and add the Neon repos, works really well. Remember Neon is not a distro, it is a customised repository on top of Ubuntu LTS.
Once added you need to remove wicd to allow KDE to handle the networking, but that is about it. Having said that chromium has just decided that the plugins for netflix should not be enabled. I problem to work on today.
Tried that, but then the compositor always crashes at startup and starts using XRenderer
  Armbian fix, current version now works Sb2024 0 2,793 08-08-2025, 08:49 AM
Last Post: Sb2024
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 3,573 09-30-2022, 10:09 AM
Last Post: crazyquark
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 7,835 08-25-2022, 02:15 PM
Last Post: Niko
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 4,084 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
  Anyone can get deep sleep fully works with NVME rootfs? plumlis 0 4,693 01-11-2021, 09:58 AM
Last Post: plumlis
  Possible to install KDE Neon on PinebookPro? Pinoideae 11 20,920 10-27-2020, 10:09 AM
Last Post: firefox-58
  Powershell on Manjaro...works great gabeeg 0 3,648 07-28-2020, 06:04 PM
Last Post: gabeeg
  Linux distro for Pinebook Pro where Suspend works appdev46 6 13,946 03-29-2020, 10:03 AM
Last Post: xmixahlx
  Preinstalled Debian version? tophneal 27 50,328 11-14-2019, 11:15 AM
Last Post: u974615
  Which Kernel Version? jaylittle 10 21,096 09-16-2019, 08:03 AM
