Kernel 5.2 and OpenSource Mali Driver
(08-17-2019, 01:35 PM)sdgathman Wrote:
(08-13-2019, 05:38 AM)matze79 Wrote: Got 5.2 up and running Smile
Lets check for MESA Driver and DRI Smile
Running Fedora 30 with kernel-5.2.8, here is what inxi -G shows:
Graphics:
  Device-1: sun50i-a64-mali driver: lima v: kernel
  Device-2: sun8i-a83t-dw-hdmi driver: N/A
  Display: x11 server: Fedora Project X.org 1.20.5
  driver: fbdev,modesetting resolution: 1920x1080~N/A
  OpenGL: renderer: llvmpipe (LLVM 8.0 128 bits) v: 3.3 Mesa 19.1.3
I have no trouble playing videos, and glxgears gets 130FPS.  I have no plans to play even tux racer...
What I most want to see working is CPU scaling.  Second most is internal wifi.
Did you build fedora for the pinebook by yourself or did you follow any project release?
It would be interesting to share your configuration with the community Wink
Thanks!
Does anyone know what Kernel driver would be needed to get the old first generation (non 1080p) Pinebook's screen working in 5.2?
(09-23-2019, 01:11 PM)macacob Wrote: Does anyone know what Kernel driver would be needed to get the old first generation (non 1080p) Pinebook's screen working in 5.2?
Should that not be the same driver?
The GPU and in fact almost the whole SoC is the same, only the display control for the LCD is different and I don't think that matters for this case?
You may be correct, but if so, why are distros separated by original pinebook and pinebook 1080 on the pine installer tool and elsewhere? I can attest that some of these do not install/function correctly when installed on first gen pinebooks.  They do work (mostly) when connected to an external monitor.
  Pinebook Wlan Driver does not work properly matze79 2 7,300 12-15-2019, 02:50 AM
Last Post: matze79
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 14,751 08-14-2019, 04:27 AM
Last Post: matze79
  kernel 4.x erchache2000 6 13,591 11-21-2018, 12:10 PM
Last Post: boballen55
  PPP support & kernel update eblot 0 3,681 11-13-2018, 04:58 AM
Last Post: eblot
  4.X Kernel? Corkonian 1 5,891 09-14-2018, 06:21 AM
Last Post: Luke
  How to test the emmc(usdhc2) diver and pwm backlight driver? vinothkumar 0 3,513 12-29-2017, 11:40 PM
Last Post: vinothkumar
  Q4os upgraded from Jessie to Stretch - how to upgrade kernel tillea 4 9,458 11-02-2017, 12:24 AM
Last Post: q4osteam
  Looking for the Mali support... rondoor 1 5,608 10-06-2017, 03:47 AM
Last Post: leszek
  Understanding Kernel Choice fordiebianco 3 8,654 07-02-2017, 07:33 AM
Last Post: fordiebianco
