PPP support & kernel update
/usr/sbin/pppd
Couldn't open the /dev/ppp device: No such device or address
modprobe: FATAL: Module ppp_generic not found in directory /lib/modules/3.10.105-bsp-1.2-ayufan-140
/usr/sbin/pppd: Please load the ppp_generic kernel module.
It seems PPP support has not been enabled in the default kernel (Linux pinebook1080p 3.10.105-bsp-1.2-ayufan-140 #1 SMP PREEMPT Tue Oct 30 14:21:35 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux). This is a very important module for supporting, among other, VPN connections.
Along with the threads about using a modern kernel, are there some limitations about using a 4.9+ kernel on the Pinebook.
I'd like to recompile the modules I need, and I'd prefer to use a recent kernel to support new peripherals.
Is there a forum topic (or any other doc) about how to safely try new kernels on the Pinebook 11.6" w/o bricking the eMMC working installation?
I guess the easiest solution is to boot from a microSD, I'd like to have a couple of pointer on how to do this safely w/o re-inventing the square wheel Tongue
Thanks in advance,
Manu
Question Ran apt update on my Pinebook.. ford442 0 6,131 12-25-2020, 04:40 PM
Last Post: ford442
  Kernel 5.2 and OpenSource Mali Driver matze79 13 29,227 09-27-2019, 11:09 AM
Last Post: macacob
  KDE Neon Image - Where can i find the Kernel Source ? matze79 4 13,960 08-14-2019, 04:27 AM
Last Post: matze79
  kernel 4.x erchache2000 6 13,044 11-21-2018, 12:10 PM
Last Post: boballen55
  4.X Kernel? Corkonian 1 5,673 09-14-2018, 06:21 AM
Last Post: Luke
  Q4os upgraded from Jessie to Stretch - how to upgrade kernel tillea 4 9,109 11-02-2017, 12:24 AM
Last Post: q4osteam
  Looking for the Mali support... rondoor 1 5,452 10-06-2017, 03:47 AM
Last Post: leszek
Information How to manage Wifi in xenial-i3 i3wm image UPDATE MarkHaysHarris777 4 10,585 09-14-2017, 12:12 AM
Last Post: dahni
  Understanding Kernel Choice fordiebianco 3 8,323 07-02-2017, 07:33 AM
Last Post: fordiebianco
  Update software needs more space mspohr 3 8,979 05-09-2017, 07:04 PM
Last Post: pfeerick
