Update software needs more space
I checked for updates in Ubuntu Mate and there were a few. Went to install them and it told me that there wasn't enough space in /boot to download. It needed an additional 17 meg.
Looks like it's using the boot partition to download and install updates... need to have it use another partition with more space but I'm not sure how to go about doing that.
(05-09-2017, 03:37 PM)mspohr Wrote: I checked for updates in Ubuntu Mate and there were a few. Went to install them and it told me that there wasn't enough space in /boot to download. It needed an additional 17 meg.
I plan to upgrade the eMMC on my pinebook before I screw around with updating the OS.  You can then prepare the eMMC anyway you would like (number and size of partitions).
Also, you might want to back-up your eMMC before playing around with it.
I reported this a few days ago -- for now update via commandline
Yeah, on the last of the April pinebook images at least, the file system was partitioned like this (and before anyone asks... this is the eMMC... not microSD, as there was no microSD card in the pinebook when fdisk -l was run Wink ):
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk0p1       40960   143359   102400   50M  c W95 FAT32 (LBA)
/dev/mmcblk0p2      143360 30310399 30167040 14.4G 83 Linux
So you'd need to do an offline resize of both partitions... i.e. boot from the microSD card, and then used something like gparted to then shrink and move down the linux partition, and then enlarge the boot partition.
Or as Luke said... upgrade from the command line / terminal for now... using sudo apt-get update && sudo apt-get upgrade. That will run without any any issues Wink
Question Ran apt update on my Pinebook.. ford442 0 6,258 12-25-2020, 04:40 PM
Last Post: ford442
  Installing software cmh2010 5 10,733 05-30-2019, 02:54 AM
Last Post: markcuban56
  PPP support & kernel update eblot 0 3,642 11-13-2018, 04:58 AM
Last Post: eblot
Information How to manage Wifi in xenial-i3 i3wm image UPDATE MarkHaysHarris777 4 10,855 09-14-2017, 12:12 AM
Last Post: dahni
Information Software Updater errors pfeerick 8 16,644 08-25-2017, 08:48 AM
Last Post: combs
  Ubuntu Mate 'Welcome' and Software Boutique. AndyK 4 9,684 06-29-2017, 12:55 AM
Last Post: Ajinkya
