Ubuntu Mate 'Welcome' and Software Boutique.
Not sure if anyone is tracking issues but I flashed Ubuntu 0.5.5-65 onto my new 64g EMMC last night and have been exploring.
Very pleased so far - the Pinebook is awesome.
Anyway one thing I did spot was that the 'Software Boutique' which is part of Ubuntu Mate Welcome seems to show no available software and crashes after a few minutes. Having been away from Linux for a bit, I was hoping this would show me the 'best in class' apps rather than have to trawl through everything on one of the many package catalogs and managers.
The reason it crashes, it  seems, is because it doesnt know about ARM builds and since the Pinebook is ARM it shows no available software which then crashes the Boutique.
Can you folks in the Pine community lobby the Ubuntu Mate team to support ARM apps?
Until then: sudo apt-get install ....
Andy
I think the problem with the Mate Software Boutique really is that it has no software collection for arm64 in general. So to raise awareness I would file a bug report against that on the Ubuntu Mate bugtracker..
there is the search function in synaptic package manager to view packages that are in the repos you use. software boutique for me was a constant false hope in that it displayed packages that where in fact unavailable whereas synaptic just shows what you have in your repos.
Yeah at the moment I would either use apt on the terminal or Synaptic on the GUI. The easy to use updater and software installers seem to be a bit broken for ARM64 right now...
Yes, I was facing the same issue. It seems that Ubuntu does not support ARM64 currently. There are a few workarounds mentioned here that you may try: https://forum.pine64.org/showthread.php?...2#pid28522
But I guess most most beginners (myself included) will have to wait until this is sorted out.
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,516 06-11-2019, 01:36 PM
Last Post: k_mp
  Installing software cmh2010 5 10,457 05-30-2019, 02:54 AM
Last Post: markcuban56
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 24,144 05-01-2019, 12:09 PM
Last Post: frank-zappa
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 15,945 12-02-2018, 05:37 AM
Last Post: mikee3000
  Pinebook Ubuntu XFCE screen resolution options Fox7799 2 7,254 12-01-2018, 06:05 PM
Last Post: Fox7799
  Pinebook 11.6" sound with Ubuntu XFCE Fox7799 1 5,260 11-21-2018, 12:54 PM
Last Post: Fox7799
  Is there a guide somewhere how to upgrade Ubuntu on Pinebook? dejan 7 14,820 11-16-2018, 12:37 AM
Last Post: icemeister
Smile Ubuntu Release Upgrade (16.04 => 16.10 => 17.04) working stohn 19 36,547 10-21-2018, 03:34 AM
Last Post: soupbowl
  Ubuntu 18.4?? Corkonian 6 13,216 09-12-2018, 07:36 AM
Last Post: Corkonian
  Problems to install qemu on Xenial Mate (for EMMC) demian 1 5,434 03-14-2018, 08:43 AM
Last Post: xalius
