Looking for the Mali support...
Recently, I know there is a way to enable Mali-400 support from here.
https://github.com/ayufan-pine64/linux-build/releases
I did same things as the introduction said, such as installing xserver-xorg-video-armsoc-sunxi and libmali-sunxi-utgard0-r6p0, Updating a kernel, a u-boot and packages. And I executed the script by typing pine64_enable_sunxidrm.sh . Then, it told me to reboot my pinebook. After rebooting, I checked whether the Mali works correctly or not by glmark2. Unfortunately, it said..
GL_VENDOR:     VMware, Inc.
GL_RENDERER:   Gallium 0.4 on llvmpipe (LLVM 3.8, 128 bits)
GL_VERSION:    3.0 Mesa 12.0.6
I thought this meant I failed to enable it. So I tried many times but the results are always same . Sad
How can I enable it? And, did you success to have the Mali work on your pinebook?
I need your advice. And I apologize for my poor english.
I think this is correct.
Also have the sunxidrm driver in use here and inxi shows me the same Gallium 0.4 on llvmpipe.
  Kernel 5.2 and OpenSource Mali Driver matze79 13 29,320 09-27-2019, 11:09 AM
Last Post: macacob
  PPP support & kernel update eblot 0 3,553 11-13-2018, 04:58 AM
Last Post: eblot
