Not able to boot Armbian 5.75@Rock64 4GB
i'll trying since days to boot following image on my Rock64:
Armbian_5.75_Rock64_Debian_stretch_default_4.4.174
Flashed it via etcher without any problem.
As soon as I boot I'll get after one minte a Exception stack ....
Exception Stack
I'm able to flash and boot Ubuntu 18.04 Bionic minimal 32bit Image.
There I have troubles to find/install the WLAN adapter.
I wanted to buil a Home-SIEM with the Rock64 (https://medium.com/@fbotes2/secure-dns-i...faa85bd833)
My Setup:
ROCK64 SINGLE BOARD COMPUTER
DRAM: 4GB
ROCK64 USB 3.0 Dual Band 1200Mbps WIFI 802.11A/B/G/N/AC (RTL8812AU) Adapter
1 $21.99
32GB CLASS10 MICROSD CARD
Have somebody a clue or hint?
i installed a copy of this last week and it worked good. i'd suggest unplugging the usb wifi card and then boot to see if that is causing the issue. if it still does not boot try burning another image. wait until you go through the setup and get a desktop and then insert the wifi adapter.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,264 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,629 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 100,289 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,300 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,995 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 14,006 11-03-2025, 09:25 AM
Last Post: darkfader
  PXE Boot example? lewis 7 18,838 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  can rock64 4gb ram run entirely on free software? heocb 1 4,191 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,414 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  How to boot an older, working kernel bits 0 3,239 11-01-2024, 04:43 PM
Last Post: bits
