(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
#51
(03-31-2016, 08:44 AM)DaveKram Wrote:
(03-31-2016, 04:40 AM)Luke Wrote: I think I may have some further insight. I tried arch and remix os today and same thing happens with the ethernet cable connected. It looks like other people with 2GB boards are having the same problem (e.g. look here: http://forum.pine64.org/showthread.php?tid=488).
[edit] plugging in the ethernet after booting up remix os causes an instant crash followed by endless bootloop
[edit 2] just tried arch - the exact thing happens as with Ubuntu
Yeah, I tried arch last night as well - the same issue happens. My model is the 2gb model. Haven't tried Remix though. I haven't experienced a boot loop in Ubuntu or Arch though - the kernel just oops and sits there (I cant type in the terminal) -> which i think is the kernel panicking.
Starting to wonder... They had supply issues with the Ethernet IC I think they said after the quake in Taiwan. I wonder if they got ahold of a bunch of counterfeit or B grade chips while trying to fill their supply lines once again. I'd sure like to know if they boot tested these boards with anything.
#52
(03-31-2016, 08:51 AM)rahlquist Wrote: I wonder if they got ahold of a bunch of counterfeit or B grade chips
The RTL8211 chips used on Pine64 are used in dumb mode (PHY only) since the MAC who does the real work sits in A64 processor. So no worries... even grade D chips would work flawlessly if they would exist and the whole problem seems to be related to DRAM capacity for yet unknown reasons.
#53
Dont think its a problem with the IC (although my knowledge on this subject matter is limited). What I do know for sure, however, is that they have not boot tested the 2gb boards because with the ethernet cable connected nothing works. Kind of hard to overlook such an issue wouldn't you say Wink  I hope this gets solved soon ...
#54
Is anyone of you 2GB users equipped with a serial console and can tell us how the output of 'Pine64 model: ' looks like when u-boot is starting?
Background: See the comment to this commit.
#55
(04-01-2016, 04:23 AM)Andrew2 Wrote: Is anyone of you 2GB users equipped with a serial console and can tell us how the output of 'Pine64 model: ' looks like when u-boot is starting?
I attached one to my post; and have done the same again for this one. Thanks for looking into this.
The log shows:
Pine64 model: pine64-plus
.txt   pinea64-boot.txt (Size: 65.25 KB / Downloads: 721)
#56
(04-01-2016, 04:49 AM)Jagmn Wrote: The log shows:
Thx, then DRAM detection works and the correct .dtb is chosen:
DRAM:  2 GiB ... get Pine64 model from DRAM size DRAM >512M Pine64 model: pine64-plus
Unfortunately no more ideas... just one: which is the exact model number of the PHY used on the 2GB model? RTL8211...?
#57
Looking more at that log file, I see this:
** Unable to read "uboot.env" from mmc0:1 ** Using default environment --------fastboot partitions-------- mbr not exist base bootcmd=run mmcbootcmd bootcmd set setargs_mmc key 0 recovery key high 12, low 10 fastboot key high 6, low 4 no misc partition is found to be run cmd=run mmcbootcmd update dtb dram start update dtb dram  end serial is: 041051900804281c034b get Pine64 model from DRAM size DRAM >512M Pine64 model: pine64-plus
It can't load uboot.env and then the default settings are used and  DRAM is 512M? Am I reading that right? Or is that saying DRAM is greater than 512 and the plus model is chosen?
Clearly says greater than 512 and the model is pine64-plus.
#58
It would be interesting how a complete boot log looks like when using the pretty outdated Arch/XFCE image since then Linux only detects 1 GB of DRAM and the Ethernet problem doesn't occur.
The aforementioned Arch image misses all fixes/improvements longsleep made the last 4 weeks so maybe it's possible to find the culprit by comparing. At least a boot log might help...
#59
I got a 2GB model in the mail today. So i guess i can look into this now Smile
#60
(04-01-2016, 10:40 AM)longsleep Wrote: I got a 2GB model in the mail today. So i guess i can look into this now Smile
May the computer gods bless you longsleep ! Smile
  Ubuntu server 20.04 request phi0x 2 11,164 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,629 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,013 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,627 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,558 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,789 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,393 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,879 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,734 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,642 08-23-2017, 09:28 AM
Last Post: gilbertotcc
