RETRO-GAMING: ANNOUNCING BETA RELEASE OF RECALBOX FOR THE ROCKPRO64
ANNOUNCING RECALBOX FOR THE ROCKPRO64 - BETA RELEASE
After many efforts with much teamwork, collaboration, and testing, we are very excited to provide the BETA release of RECALBOX for the ROCKPRO64 board!
-- The download is located under this repository's releases --
https://github.com/mrfixit2001/recalbox_...4/releases
Details on the ROCKPRO64 SoC can be found here: https://www.pine64.org/?page_id=61454
For those of you unfamiliar with Recalbox: https://www.recalbox.com/
"Recalbox offers a wide selection of consoles and game systems. From the very first arcade systems to the NES, the MEGADRIVE, 32-bit platforms (such as the Playstation) and even Nintendo64. With Kodi already included, Recalbox also serves as a Media Center. By connecting it to your home network, you will be able to stream videos from any compatible devices (NAS, PC, External HDD, etc.)."
Please do keep in mind that this is a BETA release, which means you should still EXPECT some things not to work quite right. We have done a LOT of testing on our own to try and resolve as many issues as we can before this release, but now you get to help! (Lucky you!) So if/when you do find things that don't work right, please use the link in github to report the issue.
When reporting issues:
- Provide logs and/or screenshots of the issue so that we can see the error(s) you are seeing
- Provide detailed steps for us to follow in order to reproduce the issue
We STRONGLY recommend that you install a heatsink on the board
CPU intensive tasks, such as 4K playback and demanding emulators, can create a substantial amount of heat. You can monitor your board's temperature and stats by enter it's IP address in a browser.
Improvements Since the Alpha Release:
Kernel Updates:
- Updated to version 4.4.169
- Various custom kernel fixes, mainline backports, stability and other enhancements
- 4K Playback @ 60fps is now smooth and Audio/Video are synced
Emulator Updates:
- Updated versions of many emulators and cores
- Buggy button re-mapping issue is resolved
- PPSSPP now performs at 100% speed for most games
- Customizable "max fps" setting in PPSSPP to fine tune your experience - set to 30fps to play GOW nice and smooth!
- PSP video scenes now play perfectly
- VirtualJaguar is now fixed and playable
- NEOGEO Core Fixed
- Bluetooth Controllers Reconnect After Reboot
Rockpro Specific Updates:
- WIFI and Bluetooth Module working (https://www.pine64.org/?product=rockpro6...4-1-module)
- RTL8812EU USB Wifi adapter working (https://www.pine64.org/?product=rock64-u...au-adapter)
- eMMC boot issues resolved
- Headphone / Audio-Out (ES8316) Fixed
- PCIe is enabled and connected storage devices have been confirmed to work correctly
- Improved Gigabit Ethernet performance
- Custom optimized resolutions for Mupen, PSP, and Reicast to hit 100% emulation speeds!
- EmulationStation menu music always playing
Some things that have been added to Recalbox that are Exclusive to my Pine64 releases:
- Upgraded Kodi (and addons) from version 17 (Krypton) to version 18 (Leia) alpha release
- Netflix Kodi app is included – you can login but it does not currently play anything (yet)
- Slight default overclock
- HDR and 4k Media Playback!
- Included Wolfenstein 3D (shareware version) in DosBox
- CEC working in KODI
- IR working in KODI – supports multiple remotes out of the box, including the Pine64 / Rockbox remote
- Provided some emulator default settings, shader presets, and default cores
- Updated Library Versions with Buildroot 2018.2-3
- Custom patches to ES and Emulators to improve overall stability
A few things to know about this release:
When the image first boots, you can expect a delay as the partition is expanded to the full size of your disk. Please be patient and let this complete. It will not happen on every boot, but you should not interrupt this process or you may need to reimage.
Some controllers will work with KODI right out of the box without the buttons needing to be mapping (like the x360). For others, once you hit a button on the controller it will ask you to map them - you will need a keyboard to interact with KODI until your controller buttons are mapped.
N64 has multiple core options, different ROMS work better with different cores! So if your game isn't running well, try another core! So far even the most demanding games have been found to run perfectly with the right core selected.
Some emulators / cores are highly dependent on a valid BIOS files being installed (Dreamcast, for example). Be sure to read the documents in the system’s ROM folder for details on what BIOS files are needed. Further documentation is available on the Recalbox wiki.
A single ROM not working is not considered a "bug", it's often an incompatibility with the ROM and the emulator / core. We have provided multiple cores for some emulators to try and help maximize the number of ROMS that work.
If you are suddenly and unexpectedly thrown into KODI, then that means EmulationStation may have crashed. Please provide your /recalbox/es.log file so we can review.
"Where's the source code?" The source is being cleaned up and organized in preparation to be made available for the recalbox team to maintain, instead of having it hosted in this repository. Merging it with the recalbox repo allows them to maintain and update it, which ensures that you will receive their updates as they are made available.
Lastly, please remember this is a community build, and just something I've worked on in my free time. There's no pressure at all, but if you appreciate the work then feel free to send me a buck on Paypal: mrfixit2001 at gmail.
Special thanks go out to the LibreELEC and Recalbox teams, as well as LukasZ at Pine64 for his huge efforts in research, testing, and feedback!
Mr Fix-IT
Big Grin
Sweet! Look forward to testing it out for you guys when I get ahold of my RockPro64!  Blush
ayufan's kernels past 4.4.138-1100 don't have functional HDMI audio, so I'm using 4.4.138-1100 on my system.
Does your custom 4.4.169 have HDMI audio fixed ? (I don't use 3.5mm jack, only HDMI.)
I really, really, really need to break free of 4.4.138!
Yep! HDMI audio is good to go!
It's looking good so far! I've tried the PSP emulator and it works pretty well. The Dreamcast emulation is excellent. I'll be testing it some more tonight.
I haven't found any issues with the build. Tekken 6 and Burout on PSP run great. Dreamcast works well too. Kodi is nice an smooth.
Kodi looks great! I've tried some N64 ROMs, and all but Perfect Dark ran without tweaking. Perfect Dark is working after trying different emulators. The only problem I'm running into is that the fan isn't coming on. The fan works in Android 8 (always on) and Armbian. Any ideas?
Are there any plans for enabling the MIPI display port?
(01-14-2019, 01:11 PM)laserguru Wrote: Kodi looks great!  I've tried some N64 ROMs, and all but Perfect Dark ran without tweaking.  Perfect Dark is working after trying different emulators.  The only problem I'm running into is that the fan isn't coming on.  The fan works in Android 8 (always on) and Armbian. Any ideas?
Fan doesn't work - you can connect it to the 3v or 5v and gnd GPIO headers.
[edit] Perfect Dark didn't run well ? was one of my testing games during development ... I think that it runs well on the default core. Which core did you end up using, mk2 ?
Perfect Dark happened to be one of the N64 games I tried as well. It seemed to work fine without any tweaking needed, but when I tried to use the spy camera gadget it just showed a black texture so I think it had some kind of bug there.
good feedback so far! Smile Thanks!
Pitcrawler - thanks for taking a look and letting us know things are looking good! And as you know, different roms play differently on different cores, so you did exactly the right thing by trying another core. I'm glad you found one that worked for you. While *most* games will probably perform near-perfect with the default N64 core (glupen), sometimes a rom will perform better or have less bugs with a different core. Definitely true!
laserguru - thank you also for the feedback! Can I ask what your use-case is for the DSI in recalbox/kodi?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,581 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 181,095 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,285 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,120 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,182 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,403 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 130,818 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,765 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,239 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,799 01-13-2023, 06:21 PM
Last Post: misterc
