power supplier
On the store there are power suppliers 12V 5A and 3A. I have 12V 2A from cubietruck. Will it be enough?
(12-07-2018, 10:08 AM)radek Wrote: On the store there are power suppliers 12V 5A and 3A. I have 12V 2A from cubietruck. Will it be enough?
In the early days I ran mine with a 900mA psu - worked fine. But my only addition to the board (at that stage) was a Bluetooth USB dongle.
Potentially you can add some fairly demanding (of power) peripherals to USB3 & PCIe, let alone the DC-out or USB2, at which stage even the 5A will not be enough. So it depends what you plan to add.
And, like all of these maker boards, there are some nasty cheap psu out there that despite what they say on the label, are not good enough except as paperweights.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,749 05-28-2026, 05:29 PM
  Rock Pro 64 Won't power on matthewmkr 9 8,814 04-29-2025, 12:57 PM
Last Post: matthewmkr
  power button not working Vista8720 0 3,409 05-07-2024, 11:26 PM
Last Post: Vista8720
  enble boot after power loss/restore dkebler 18 30,510 12-04-2023, 12:14 PM
Last Post: ok38
  PCIE interface power on too late Slark Xiao 0 3,001 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Automatic power on after power outage gechu 1 6,010 11-17-2022, 06:13 PM
Last Post: acj_
  After Power Loss feature working bdherouville 2 6,042 08-22-2022, 03:52 AM
Last Post: bdherouville
  PWM fan control low power Connar 0 2,981 12-12-2021, 05:58 AM
Last Post: Connar
  ROCKPro64 sometimes doesn't Power On Pete Tandy 2 6,668 08-24-2021, 05:50 AM
Last Post: Pete Tandy
  Power Supply availability S265 2 7,047 06-07-2021, 09:20 PM
Last Post: S265
