WiFi support on RockPro64
Is there a way to re-enable `sdio` and get the rockpro wifi/bt module to work on linux?
(11-19-2018, 08:19 AM)tagyro Wrote: Is there a way to re-enable `sdio` and get the rockpro wifi/bt module to work on linux?
I know about https://forum.pine64.org/showthread.php?tid=6310 but there is not solution mentioned there either!
There is progress being made here but nothing available to download yet. It's coming! Smile
Thank you for the update, will keep an eye on the wiki and the forum!
Last time I simply enabled sdio0, I got a kernel panic.
Not having enough time or skill, I just re-disabled it and got a USB wifi stick.
it's even more stable if you connect the ethernet jack to a wifi bridge device (I used an ASUS RP-AC56 repeater in "media bridge" mode).
wifi in linux in general is extremely hard, even with "supported" devices. ethernet bridge is the most stable way to go Big Grin
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,586 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 181,247 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,287 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,122 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,186 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,411 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 130,862 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,767 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,240 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,815 01-13-2023, 06:21 PM
Last Post: misterc
