What happens if you under-power voltage?
If you have 2.1 V versus 5.1 V, does it not boot or is it very slow?  Huh
TechieManny   Shy
Fortunately it doesn't boot. Please keep in mind that Pine64 uses Micro USB for DC-IN so if you're using common USB cables (resistance way too high) you're already risiking undervoltage situations. Using a quality PSU that is immune to voltage drops even with increasing consumption and a good cable is a must when you want to enjoy your board.
BTW: Is it possible that you enlarge your signature image a bit?
(03-29-2016, 10:02 AM)Andrew2 Wrote: ... Micro USB for DC-IN so if you're using common USB cables (resistance way too high) ...
Andrew2 - How much resistance is way too high? Maybe a better question is, what is ideal range of resistance?
Thanx
(03-29-2016, 10:02 AM)Andrew2 Wrote: Fortunately it doesn't boot. Please keep in mind that Pine64 uses Micro USB for DC-IN so if you're using common USB cables (resistance way too high) you're already risiking undervoltage situations. Using a quality PSU that is immune to voltage drops even with increasing consumption and a good cable is a must when you want to enjoy your board.
Thanx
Look at the cable whether it says something like 28AWG - that is bad cable. 20AWG - good cable Smile
more on this https://en.wikipedia.org/wiki/American_wire_gauge
resistance of the 28AWG cable is 6 times more than 20AWG cable
  New RockPro64 Power Up Problem enorbet2 7 13,094 10-28-2023, 12:08 PM
Last Post: dkebler
  Pinecil power Erincka 0 3,316 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,428 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,285 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 23,611 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,174 06-17-2020, 02:00 AM
Last Post: hanscees
  User Screen Black After Changing Power Settings 0b51Gekko 2 7,769 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 11,526 02-12-2017, 09:34 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 3,932 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  Power Ribbon for LCD Display Plot 3 9,414 10-23-2016, 12:16 PM
Last Post: dkryder
