Wifi I/F on Pinebook 11.6"
What's the difference between the wlan0 and p2p0 WiFi adapter.
I guess there's only one WiFi adapter on the Pinebook, so why both are listed?
It seems that the Pinebook, even configured to use wlan0 with a wifi network sometime connects to it through the other, "shadow" p2p0 interface.
This leads to an unexpected effect, as the DHCP server assign a different IP address depending on which I/F is used. This is due to different MAC addresses of the I/F, as p2p0 uses a 02: prefix while wlan0 uses 00:
Any piece of info about this topic?
Thanks,
Manu
p2p0 uses the same hardware as wlan0, bit it is used only for WiFi Direct peer-to-peer wireless connections.
(11-13-2018, 06:43 AM)jschall Wrote: p2p0 uses the same hardware as wlan0, bit it is used only for WiFi Direct peer-to-peer wireless connections.
How can I remove the wifi/ bt card?  Or how can I safely neutralize it?
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 13,845 05-18-2026, 02:11 PM
  DietPi OS for Pinebook MichaIng 3 15,448 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 99,369 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,350 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,063 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 15,287 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 7,906 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,079 01-04-2022, 09:22 PM
Last Post: irongarment
  Wifi doesn't work correctly Fredric92 1 7,983 08-10-2021, 08:39 AM
Last Post: Jean-Marc LACROIX
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 10,754 05-07-2021, 10:20 AM
