Feature u Think we need to improve?
Audio
51.16%
22
Rear Video
13.95%
6
GPS
34.88%
15
43 vote(s)
Pine64 Head Unit
#21
Voice control and Hands-free phone calling would be nice. (Requires wifi/BT module, not a big deal)
If I've helped you with something, please leave a rating for my responses.
#22
Voice control just using the
Google now (with wifi connection or using a data modem)
Call's
well that's pretty harder cuz there's no connection android to android available to do that
Or for streaming audio from android to android
I'm my car i have already a head unit with Bluetooth and phone function
My idea is to add the pine64 as a main screen
Stream audio via Bluetooth from the pine64 to my head unit
The good thing is that my head unit allows me to connect 2 devices at the same time so my phone and the pine64 will be connected
And just use it as receiver and at this manner I can use my amp system Smile
But main audio source will be the pine64
If there is a way to use it as a phone receiver via Bluetooth an charging plus let me know so I can work with that
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
#23
Hi guys,
So I've designed the following:
1. Power up circuit using Car's battery, ground and ignition signals. Pine64 will be powered on as long as the key is in the ignition and the engine is on.
2. 4 channel (FL, FR, RL and RR) analog audio amplifier (each channel delivers 50W).
3. Sound processor with 3 band equalizer (mid, bass, treble).
Currently I am working on a layout (not a layout guy - if someone has experience with KiCad, please let me know I could use some help). I will put all of these on one board (POT) that will plug in on top of Pine64.
I plan to have this completed in the next couple of weeks. I will keep you posted on the progress.
(03-04-2016, 02:46 AM)npull Wrote: a USB charger is a 12V to 5V converter, isn't it?
Using it's own battery was an alternative I was thinking of. Then you can monitor charging state instead, wake up when charging starts, go to sleep mode when charging stops. But how long would, lets say nexus 7's 4,325 mAh battery last in sleep mode for the pine64? What happens if you leave the car for a week and it dies, how can you then turn on the pine64 with the ignition?
From the car, you have Battery, Ground, and Ignition (Accessory) wires (signals).
Pine64 has DC_in on one of the connectors, which is I believe 5V. You would have to connect the two.
How:
Car's alternator will produce around 13.6V, so you will need a step down converter, to get to 5V. Ideal amperage for Pine64 (according to Pine64 folks) is 2A.
So, look for the converter with the above specs.
Also, you don't want Pine64 to drain your battery when the alternator is off (car is off). This is where Ignition signal comes in. You would need to connect Ignition signal to a power transistor (MOSFET) that would control another power transistor on the Battery line.
I hope that makes sense.
#24
Makes sense.
However I think I'm not in the line of using a small battery to power the pine64 in sleep mode, for faster startup... lets say I go to fill up the car, or stop for some snack while on a trip, I then don't want to have to wait for boot up, gps software to start up, put in the destination again, and so on... So all I need is the ignition power, and when that goes off it continue on battery and go to sleep mode.
For Zoidiano0:
I also got an old nexus 7 lying around, so thinking of using it's battery. Do you know how the wiring for that battery works? There is 6 cables, two red, two black, one yellow and one white. Is the reds and the blacks just double +/-? Guessing for increase cable mm^2 while keeping as flat as possible? Or is there a reserve compartment? And is any or the white or yellow for temp control? is that usable for the pine64's temp control?
#25
Hi guys sorry for my late response
Well from. What I'm seen there are some ways of how to power the pine in the car
My best guess of how I'm going to connect it is this
Using the DC DC converter provided by dalasu connected to ground and accessory cable of my car so the screen can wake up at the start and to power it when acc it's not set I'll use my Nexus 7 battery witch I have already take it a part
( I'm going to chek what those 2 cables white and yellow does to know if we can use them)
The 2 + and - are the same spot in the board I check continuity in t3 circuit earlier
I'll do some testing and I'll who comment the result later on
I'm Also going to the prototyping shield of the pine64 I'm going to build a schematic of my system on the circuitmaker to See how it can look
Keep working on your ideas for the project and comment
C Ya
By. Zoidiano0!
Installed:
Netbeans 8.1
#26
Hi guys well news from the nexus 7 battery charger
i have done some testing with the nexus 7(2012) battery and circuit board (of the batt)
and well
i notice that the White cable its giving me the voltage that the battery already have
and the yellow cable is telling me the temp of the batt( not sure about this one )
i try this attaching to the board terminal's other batteries pulled from old laptop battery with different voltages and getting different results so this is for me this is how those pins works
now we have to know if the extra cable of the pine64 batt is giving us the same data
then  we can be able to use it on the pine
if not we can still use it to power it Big Grin
By. Zoidiano0!
Installed:
Netbeans 8.1
#27
Hi.. I just wanted to say I found out about this in last week's newsletter. I just lurk on the forums, but I just wanted to say that I'm all for a head-unit. This is an idea I've been tossing around in my head after picking up a car the other week that desperately needs something other than the stock head-unit.
Questions... there's a lot to read and understand on the first page. I'll catch up on the info and will submit any questions that come to mind.
Thanks again for bringing this to the forum!
#28
https://learn.adafruit.com/adafruit-20w-...4/overview
adafruit do a nice stereo 20w amp board, i used one in an old van instead of a headunit, hooked it straight to the 12v ignition connection on the radio harness and it sounded alright
Guess a 12v regulator is more ideal but I was being lazy
also the MAX13301 is a 4 channel
https://www.maximintegrated.com/en/produ...13301.html
#29
(03-10-2016, 04:46 PM)Zoidiano0 Wrote: Call's
Maybe you can use http://www.tablettalkapp.com/faq/
As I understand you would need some bluetooth headset installed in the car as well, which pose a problem of how it will fight with the pine64 over the amplifier.
#30
Ya u r right I forgot about that app
Even tho I used to use that app before haja
Ya we can use that one for phone and sms ( no whatspt or fb)
But still remain the problem of music streaming
Maybe we can make that work later on
I'll add the app on the first post a to have the info updated and organized
By. Zoidiano0!
Installed:
Netbeans 8.1
  Pine64 as squeezebox touch replacement Learnincurve 12 40,914 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 13,900 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 6,339 08-06-2020, 12:05 AM
Last Post: tuaris
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 25,157 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 60,200 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 5,767 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 60,502 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 14,453 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 10,629 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 8,859 01-18-2018, 05:51 AM
Last Post: Luke
