No WiFi
I have plugged in the optional WiFi/BT module but no joy. It is completely ignored by the system (Ubuntu Bionic from http://wiki.pine64.org/index.php/ROCKPro....04_Bionic):
uname -a Linux rockpro64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux networkctl IDX LINK             TYPE               OPERATIONAL SETUP        1 lo               loopback           carrier     unmanaged    2 eth0             ether              routable    configured sudo lshw -c network   *-network                         description: Ethernet interface        physical id: 7        logical name: eth0        serial: 32:cb:11:5d:df:5e        size: 100Mbit/s        capacity: 1Gbit/s        capabilities: ethernet physical tp aui bnc mii fibre 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation        configuration: autonegotiation=on broadcast=yes driver=st_gmac driverversion=March_2013 duplex=full ip=192.168.1.34 link=yes multicast=yes port=MII speed=100Mbit/
Can you please advise?
Brgds, Edouard.
The BT/wifi module is currently disabled in Linux because it conflicts with PCIe. This problem will eventually be fixed and will find its way into ayufan's images.
conflict from PCI-E directly or only from booting from PCI-E NVMe devices?
When using the image 0.7.7-1057 booting from eMMC and the kernel to version 4.4.132-1068 will work?
(with PCI-E SATA-II adapter and BT/Wi-Fi module, without NVMe devices and without booting from PCI-E devices)
because sdio0 was disabled starting with the version of the kernel 4.4.132-1070
i had ubuntu running on the pinebook pro last night, but i mada a mistake and deleted the emmc content on the emmc disc. now i can only boot ubuntu from the micro sd card. It will boot the os, but importent things like the network device is gone "network device not available" How can i restore the network device? I am kinda stuck and cant move forward. Please let me know what i should do?
  AW-CM256SM wifi card mtek 4 11,442 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 21,528 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 8,265 07-20-2022, 03:31 AM
Last Post: imianz
  To Wifi or To Bluetooth, That is the Question WarpLover 0 3,365 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 6,652 03-10-2021, 12:23 AM
Last Post: Wizzard
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 4,034 11-17-2020, 04:25 AM
Last Post: pi64
  new WIFI/BT module not working with android 8.1 Firesped 0 3,750 05-12-2020, 10:33 PM
Last Post: Firesped
  Questions about the ROCKPro64 1x1 Dual Band WIFI module thelabratrules 0 3,630 04-04-2020, 03:29 PM
Last Post: thelabratrules
  Best location for adhesive wifi antennas with NAS case callegar 1 5,543 02-17-2020, 12:40 PM
  Need to add various Wifi chipset support slappymcphee 6 14,139 08-15-2019, 05:26 PM
Last Post: evilbunny
